p.map
regarding the bottom frame line, do you have any/all updates?
M. Shapiro and I went round and round about this once---there
may have been a change in the code to fix this.
--Darrell
Is there any update for this? I grazed the moon last friday but didn't
find any. Also, I think to have figured out the problem source while
writing a driver for our Stork ex1120. However, I want to be sure the
problem has not yet been solved.
Raymond Venneker
Earth Sc. VU Amsterdam
Raymond Venneker (venn@geo.vu.nl) writes on 16 Nov 92:
If there is an update, it has not been installed here. Verified by:
p.map # scaled 1 panel
xview -identify ~/paint.ppm # to get size
paint.ppm is a 800x590 Raw PPM image with 256 levels
ppmmake white 850 640 | pnmpaste paint.ppm 25 25 - | xview stdin
        # show's bottom border missing
Go ahead and submit any fix that you have.
