ERROR: tek4697 driver: RLE (got 1042, should be 1024)
Could anbody suggest a solution. I could not find this setting in any
script file. The contents of geo.1 file are as follows and legend does not
come out in the output from the printer.Sujata Prakash Ph: (513)-556-0499
DAAP Computer Graphics Center Fax: (513)-556-3288
University of Cincinnati Internet: Sujata.Prakash@UC.Edu
The RLE part must mean Run-Length Encoding, I suppose. Perhaps you can do
some checking by painting this map to the screen first (using p.select=
preview). As for the legend, this has never come out at our site either.
You will find quite some discussion of the foibles of p.map in the old
mail archives on `moon'. Still, I hope you will be able to solve both
problems....
Good Luck!
----\_\_\_--\_----\_------\_-------------------- P. Martijn van Leusen --------
\_ \_ \_\_\_\_ \_ Dept of Pre- and Protohistoric Archaeology
\_\_\_ \_ \_ \_ \_ University of Amsterdam, The Netherlands
\_ \_ \_ \_\_ \_ martijn@scanner.frw.uva.nl
--------\_------\_----\_--\_--\_\_\_\_-----------------------------------------
