paint output to file
Darrell McCauley (mccauley@ecn.purdue.edu) writes:
[regarding using p.map to send output to a file]
of course, you will not have any title, legends, etc, if you use this method.
Using p.map scripts, you can add titles, text, legends, grids, and barscales
to your output. You must use scripts, however, as the interactive version of
p.map does not present you with these options.
Chris Murphy murphyc@cgrb.orst.edu
Oregon State University / Entomology
Corvallis, Oregon USA
