On Tue, Jul 11, 2000 at 03:53:20PM -0600, kegallag@NMSU.Edu wrote:
I am attempting to use the program GRASS to obtain spatial
distances for ALL possible pairs of plant individuals within a
population. To date, I have obtained distances (not coordinates)
of individuals relative to only TWO OTHER individuals (in order
to use triangulation to create polygons). Now, I need to
calculate pairwise distances for EACH plant individual relative
to EVERY OTHER plant individual within populations. Could you
please tell me GRASS has the capability to compute the distances
between all pairs of points in a spatial network comprised of
only a limited number of pairwise distances?
Please do not hesitate to contact me if you require
clarification. I would really appreciate your input! Thanks for
your consideration.
I don't know if GRASS has a function to do this, but you can do it in
PostgreSQL. The coordinates have to be in an x,y type projection like
UTM (lat/lon won't work).
Here's how:
1. dump your plants (they are sites?) into an ascii file (s.out.ascii).
2. Open postgresql and do the following (you might have to edit the
ascii plant file to get it into a format for postgresql).
a) Create the table...
CREATE TABLE plants (
plant_id INTEGER PRIMARY KEY,
coordinate POINT NOT NULL
b) Copy the data into postgresql
COPY plants FROM '/path/to/plants.asc' USING DELIMITERS '|';
#file should look like below with x & y being the floating point coords.
1|(x,y)
2|(x,y)
c) Do a relational projection calculating the distance between each pair
of points and weeding out the zeros (this may take a long time if you
have alot of data, and may bomb if you have tons of data).
SELECT a.plant_id, (a.coordinate::point <-> b.coordinate::point) as distance,
b.plant_id
FROM plants a, plants b
WHERE (a.coordinate::point <-> b.coordinate::point) > 0.0
ORDER BY a.plant_id;
3. Send the output to a file (possible without fancy formatting). It'll
look like:
plant_id | distance | plant_id
1 | 2.54950975679639 | 2
1 | 8.74642784226795 | 3
1 | 20.2869416127715 | 4
1 | 30.500655730656 | 5
2 | 2.54950975679639 | 1
2 | 6.21288982680363 | 3
2 | 17.8488094841085 | 4
2 | 28.0251672608746 | 5
3 | 8.74642784226795 | 1
3 | 6.21288982680363 | 2
3 | 12.5483066586691 | 4
3 | 22.3895064706661 | 5
If you need help with the postgresql stuff, let me know.
According to MegaHAL:
The emu is a mass of incandescent gas, a gigantic nuclear furnace.
