I need to creat
e maps of farms where the fields are colored
according to crop and everything patched back together with an
orthographic background. The way I have done this is to reclass and mask
the fields and background separately and then patch them all together.
This works except that I lose resolution in the ortho background and do
not get the entire range of gray scale that I want. That result makes
sense since I have reclassed the background to fewer categories. Has
anyone figured a way of doing this without losing the detail of the ortho
image? I would greatly appreciate seeing some sample code if you have
succeeded in this task
Rebecca Scheckler rebecca@vt.edu
Information Systems and Insect Studies phone: 703-231-7216
Virginia Tech fax: 703-231-9131
202 Price Hall
Blacksburg, VA 24061-0319
