Does anyone know why one can't use patterns in ps.map like you can p.map?
Would anyone have any suggestions at getting around this problem? The
only way around this that I can figure out is saving a map in sunraster
format and then importing it into grass as a raster file, and then ps.mapping
the raster file. Any simpler solutions out there?
Christine
Hi Christine,
You can use the PBM filters to take the $HOME/paint.ppm output from p.map and
pipe it through pnmtops and redirect to a file. This should get you something
to print with lpr. Good luck. Rick
Rick Thompson- Research Specialist E-mail: rick@cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-8498
Ozark Hall Rm. 12 Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
DISCLAIMER: Any opinions or comments about any product, organization,
or individual expressed in the above text are my own.
