PC-based GRASS?
Is there anybody out in the world is working or will work on a PC-based GRASS
version? If we do have the PC version, what is the requirement of the CPU, disk
space, memory, video card, etc?
Please email me if you know the issue or direct me to any possible party.
Thank you.
Tao Wen
USA Construction Engineering Research Laboratory
This has been discussed in c.i.g and grass(u/p) before:
There is no 'PC-GRASS', vanilla GRASS works fine
(e.g. under SCO).
Disk space requirements are the same as with other machines
(sth like 80MB w/o data), 386/33 is quite usable, 8MB
works fine (X doesn't make sense under 8MB anyway),
video 1024x800 is acceptable if you have a serial terminal
for text i/o(or a window interface.
Basically any config. that runs your UNIX/X11 will be
alright for GRASS (given sufficient disk space.
Martin.
