There is a product on the market now that we have been particulary interested
in lately and have just gotten one installed. It is a board set from Opus
that plugs into a PC bus. This board set contains SPARC RISC processors and
for all intents and purposes, is an actual Sun Workstation. The boards come
in two flavors, SPARCard 1 & SPARCard 2.
We have some of the SPARCard 2 sets here which has the identical processing
specs as the Sun Sparc 2 computer does. It is actually the same chip. This
product is particulary interesting in that you have all of the funtionality
of the Sun Sparc 2 system while at the same time having access to the PC/DOS.
Both the DOS and the UNIX are running at the same time. You simply 'hot-key'
between the two different operating systems. Since the OPUS card is entirely
self-contained, it doesn't rely on DOS and vice-versa. This is a major
improvement over UNIX which simply has a DOS shell in it. For users needing
access to both DOS & UNIX, this is the best solution that I have come across.
