Hello,
I want to use MicroX-win X emulation software to run
GRASS 4.1 on a PC. A SUN with Solaris 2.3 is the client.
The x-software works, GRASS on Solaris works on the workstation,
but here is the error I get when I run d.mon start=x0 on the PC:
X Error: Bad Match
Request Major code 78()
Error Serial #265
Current Serial #266
Then it goes into its Please start graphics monitor error mode.
The setenv DISPLAY is set as the PC's IP number.
Any suggestions? I found similar error messages in the archives, but
could not find any solutions.
Marilyn Ruiz
ruiz@thales.geog.ufl.edu
