[pgrouting-dev] Graph contraction
Dear developers
The experimental function pgr_contractGraph bugs have being fixed
https://github.com/pgRouting/pgrouting/pull/1215
around 1900 unit tests of contraction have passed
https://github.com/pgRouting/pgrouting/tree/develop/pgtap/contraction
I have made tests with it on a real problem with a large database and things have come as expected.
So the next step is move it up from experimental to proposed, but for this step there is going to be a name change on the function to
pgr_contraction
The main reason is to remove the word “Graph” as all pgRouting functions are about graphs, and if in the future there are different techniques (say foo & bar) about contraction then the names can be:
pgr_contractionFoo pgr_contractionBar
instead of
pgr_contractGraphFoo pgr_contractGraphBar
Regards
pgRouting team
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky@[georepublic.de](http://georepublic.de)
Web: [https://georepublic.info](https://georepublic.info)
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
