Hello Everyone,
My Wiki [1]
My Forked Repository [2]
This is my report for Coding Period Week 4 (June 22th - June 28th).
What did I get done this week?
Added documentation for the function
pgr_boyerMyrvold()
which provides a short description of the function, sample usage of the function through sample queries and results, tables that explain the input parameters as well as output parameters and finally reference links to Boost’s Boyer Myrvold planarity documentation as well as Wikipedia’s explanation of the Planarity explanation. -
Removed unnecessary header files, redundant code and comments from the files.
Started designing my next planar graph boost function
boost::make_connected()
Details can be found in [3]
The merged pull request can be found in [4]
What do I plan on doing next week?
Complete designing of next boost function
Study the above boost function.
I will be creating a basic skeleton for C, C++, SQL code, and for the documentation and tests. For this, I will be adding all the required files in their required directories, containing basic code related with the new function. I will also add the function name in the configuration file and update the signature file accordingly.
Am I blocked on anything?
Currently I am getting errors on doxygen dot files on my pc.
Apart from this I don’t have any blocking issues.
Himanshu Raj
Links:
[1] WIKI
[2] Forked Repository
[3] https://github.com/pgRouting/pgrouting/wiki/GSoC-2020-Implementation-of-Edge-Contraction-Technique-in-pgRouting#week-4-june-22nd—june-29th-1
[4] Merged Pull Request
