Hello Everyone,
This is my weekly report for week [6] (Jul 7th -Jul 12th).The report can also be found in project wiki [1].
What did I get done this week?
- Created the pull request in which my weekly progress can be reviewed.[2]
- Completed the coding of SQL functions that are
pgr_mrt.sql
and_pgr_mrt.sql
. - Fix the signature of Lengauer Tarjan dominator Tree. (Rename from LTDTree to
lengauer_tarjan_dominator_tree
- Changed the name of the function in
LTDTree.c
file to solve the errors.
- Changed the name of functions in
pgTap tests
to proper testing.
- Changed the signature of the function in
pgrouting--3.0.0.sig
file.
- Able to read data from PostgreSQL for
pgr_mrt()
. - Made the c++ containers and added
boost::lengauer_tarjan_dominator_tree
algorithm for an undirected graph. But till now it returns 0 rows. - Added pgTap tests files with zero tests in
spanningTree/mrt
the directory that contains: mrt-edge-cases.sql, mrt-innerQuery.sql, no_crash_test-mrt.sql, pgr_mrt_types_check.sql.
What do I plan on doing next week?
- Complete coding of c++ containers and add
for both the undirected graph and the directed graph. - Write some tests for
andmrt-edge-cases.sql
- Prepare user documentation for
two graph common spanning tree
Meetings attended in this week
No meeting was scheduled.
Am I blocked on anything?
No blocking issues.
Thanks
Prakash Tiwari
links:
[1]. [https://github.com/pgRouting/pgrouting/wiki/GSoC-2020-Lengauer-Tarjan-dominator-tree-and-Two-graphs-common-Spanning-Trees](https://github.com/pgRouting/pgrouting/wiki/GSoC-2020-Lengauer-Tarjan-dominator-tree-and-Two-graphs-common-Spanning-Trees)
[2].[https://github.com/pgRouting/GSoC-pgRouting/pull/60](https://github.com/pgRouting/GSoC-pgRouting/pull/60)
[3].[https://github.com/pgRouting/pgrouting/wiki/GSoC-2020-Lengauer-Tarjan-dominator-tree-and-Two-graphs-common-Spanning-Trees#week-6-july-6th---july-13th-1](https://github.com/pgRouting/pgrouting/wiki/GSoC-2020-Lengauer-Tarjan-dominator-tree-and-Two-graphs-common-Spanning-Trees#week-6-july-6th---july-13th-1)
