Hello Everyone,
This is my weekly report for week [8] (Jul 19th -Jul 26th). The report can also be found in the project wiki [1].
What did I get done this week?
- Created the pull request in which my weekly progress can be reviewed. [2]
- Found the problem in
boost::two_graph_common_spanning_trees
it was not returning the output as they were expected, So mailed the issue to the boost mailing list regarding this. - Created an issue in pgRouting to discuss the signature of a new function that is
pgr_bipartite
. [3] - Improved the c++ containers of
pgr_lengauer_tarjan_dominator_tree
by removing manual mapping and made suitable containers that can work withBase Graph
. - Rebase my working branch
gsoc-prakash
withupstream/develop
where upstream is remote of pgRouting main repository. - Started coding of new function
boost::is_bipartite()
in thepgr_bipartite
in my working branch gsoc-prakash - Started and completed the coding of bipartite.sql and _bipartite.sql with the signature of
pgr_bipartite(edge_sql)
which returnsset of (vid,color)
. - Started and completed the coding of
bipartite.c
file by making and including suitable headers and functions. - Started and completed the coding of
bipartite_driver.cpp
file. Which converted the data_edge into undirected graph and also it includes all the necessary exceptions and headers. - Started and completed the coding of
pgr_bipartite_driver.hpp
. In which created proper c++ containers that can work with boost and base graph. Also called theboost::is_bipartite()
algorithm. And converted the result into a vector. - Merged the pull request of this week.
What do I plan on doing next week?
- Complete the GSoC evaluation.
- Complete the pgTap tests of
pgr_bipartite
which includes- no_crash_test-bipartite.sql
- bipartite-inner-query.sql
- bipartite-types-check.sql
- bipartite-edges-sql.sql
- Prepare user documentation with additional example of
pgr_bipartite
Blocking Issues
It is not blocking of pgRouting. But I found the problem in boost::two_graph_common_spanning_trees
it was not returning the output as they were expected, So I mailed the issue to the boost mailing list regarding this. As they will response I will continue with my rest of the coding part. Till then I started working in my next function (After discussing with mentors)that is bipartite
it was an additional idea.
Meetings attended in this week
No meeting was scheduled.
Prakash Tiwari
links:
[1]. [https://github.com/pgRouting/pgrouting/wiki/GSoC-2020-Lengauer-Tarjan-dominator-tree-and-Two-graphs-common-Spanning-Trees](https://github.com/pgRouting/pgrouting/wiki/GSoC-2020-Lengauer-Tarjan-dominator-tree-and-Two-graphs-common-Spanning-Trees)
[2].[https://github.com/pgRouting/GSoC-pgRouting/pull/80](https://github.com/pgRouting/GSoC-pgRouting/pull/80)
[3]. [https://github.com/pgRouting/pgrouting/issues/1498](https://github.com/pgRouting/pgrouting/issues/1498)
[4]. [https://github.com/pgRouting/pgrouting/wiki/GSoC-2020-Lengauer-Tarjan-dominator-tree-and-Two-graphs-common-Spanning-Trees#week-8-july-20th---july-27th-1](https://github.com/pgRouting/pgrouting/wiki/GSoC-2020-Lengauer-Tarjan-dominator-tree-and-Two-graphs-common-Spanning-Trees#week-8-july-20th---july-27th-1)
