[pgrouting-dev] GSoC 2020 - Lengauer Tarjan dominator Tree and Two graphs common Spanning Trees for pgRouting - Weekly Report [Week 9]
Hello Everyone,
This is my weekly report for week [9] (Jul 27th - Aug 2nd). The report can also be found in the project wiki [1].
What did I get done this week?
  • Created the pull request in which my weekly progress can be reviewed. [2]
  • Completed the GSoC second evaluation.
  • Completed the pgTap tests of pgr_bipartite which includes
  • no_crash_test.sql
  • inner-query.sql
  • types-check.sql
  • edges-sql.sql- Prepare user documentation with additional example of pgr_bipartite.
  • Renamed files of pgTap tests according to mentor suggationa.
  • Refined the code of c++ files.
  • What do I plan on doing next week?
  • Refine and review the code of implemented algorithms.
  • Add more pgTap tests of pgr_bipartite and pgr_lengauer_tarjan_dominator_tree
  • Prepare user documentation with additional example of pgr_bipartite and pgr_lengauer_tarjan_dominator_tree.
Blocking Issues
It is not a blocking of pgRouting. But I found the problem in boost::two_graph_common_spanning_trees it was not returning the output as they were expected, So I mailed the issue to the boost mailing list regarding this. As they will response I will continue with my rest of coding part. Till then I started working in my next function (After discussing with mentors)that is bipartite it was an additional idea.
Meetings attended in this week
No meeting was scheduled.
Thanks
Prakash Tiwari
links:
[1]. https://github.com/pgRouting/pgrouting/wiki/GSoC-2020-Lengauer-Tarjan-dominator-tree-and-Two-graphs-common-Spanning-Trees
[2]. https://github.com/pgRouting/GSoC-pgRouting/pull/112
