[pgrouting-dev] GSoC 2021 - Week-10 Report: Implement Edge Coloring Algorithm for pgRouting by the Boost Graph Library
Hello everyone,
This is the report for the Second Coding Period: Week 10 (August 9th - August 15th).
What did I get done this week?
  • Merged two Pull Requests in the pgRouting develop branch:
  • (#2061): Experimental Function - pgr_edgeColoring [1].
  • (#2084): Updating pgr_edgeColoring Doc [2].
  • Created an issue for adding pgr_edgeColoring in pgRouting:
  • (#2060): Detailed signature of the new function pgr_edgeColoring to be added in pgRouting [3].
  • Created a tag in GSoC-pgRouting containing the code of experimental function pgr_edgeCOloring: GSoC-2021-veenits123-edgeColoring [4].
  • Details can be found here [5].
What do I plan on doing next week?
  • Make the final report along with the presentation of the work.
  • Submit the final evaluation of my mentors.
  • Details of sub-tasks can be found in [5].
Am I blocked on anything?
  • No, I am not blocked on anything.
The log of Pull Requests can be found in [6].
The detailed wiki page can be found in [7].
The Public repository I am working on can be found in [8].
[1] https://github.com/pgRouting/pgrouting/pull/2061
[2] https://github.com/pgRouting/pgrouting/pull/2084
[3] https://github.com/pgRouting/pgrouting/issues/2060
[4] (https://github.com/pgRouting/GSoC-pgRouting/releases/tag/GSoC-2021-veenits123-edgeColoring
[5] https://github.com/pgRouting/pgrouting/wiki/GSoC-2021-Implement-Edge-Coloring-Algorithm-for-pgRouting-by-the-Boost-Graph-Library#week-10-august-9th—august-15th-1
[6] https://github.com/pgRouting/pgrouting/wiki/GSoC-2021-Implement-Edge-Coloring-Algorithm-for-pgRouting-by-the-Boost-Graph-Library#log-of-pull-requests
[7] https://github.com/pgRouting/pgrouting/wiki/GSoC-2021-Implement-Edge-Coloring-Algorithm-for-pgRouting-by-the-Boost-Graph-Library
[8] https://github.com/veenits123/GSoC-pgRouting
Any feedback and suggestions are welcome.
Thanks!
Veenit Kumar
