[pgrouting-dev] GSoC 2021 - Week-2 Report: Implement Edge Coloring Algorithm for pgRouting by the Boost Graph Library
Hello everyone,
This is the report for the First Coding Period: Week2 ( June 14th - June 20th ).
What did I get done this week?
  • Created the necessary class wrapper for the Boost function.
  • Worked on include/coloring/pgr_edgeColoring.hpp to read data.
  • Worked on documentation for the pgr_edgeColoring function.
  • Updated doc/coloring/doc: pgr_edgeColoring.rst, coloring-family.rst and docqueries/coloring/docqueries: doc-edgeColoring.result, doc-edgeColoring.test.sql files.
  • Made a pull request with all these changes [1].
  • Details can be found here [2].
What do I plan on doing next week?
  • Creating new files for connecting Boost.
  • Implement my own code for the Graph type and not using pgr_base_graph.
  • Create the necessary class wrapper for the Boost function.
  • Process the data with the Boost Function.
  • Details in the Gitter chat: https://gitter.im/pgRouting/pgrouting?at=60ccc7b387848634af29a743
  • Details of sub-tasks can be found in [2].
Am I blocked on anything?
The log of Pull Requests can be found in [3].
The detailed wiki page can be found in [4].
The Public repository I am working on can be found in [5].
[1] https://github.com/pgRouting/GSoC-pgRouting/pull/171
[2] https://github.com/pgRouting/pgrouting/wiki/GSoC-2021-Implement-Edge-Coloring-Algorithm-for-pgRouting-by-the-Boost-Graph-Library#week-2-june-14th—june-20th-1
[3] https://github.com/pgRouting/pgrouting/wiki/GSoC-2021-Implement-Edge-Coloring-Algorithm-for-pgRouting-by-the-Boost-Graph-Library#log-of-pull-requests
[4] https://github.com/pgRouting/pgrouting/wiki/GSoC-2021-Implement-Edge-Coloring-Algorithm-for-pgRouting-by-the-Boost-Graph-Library
[5] https://github.com/veenits123/GSoC-pgRouting
Any feedback and suggestions are welcome.
Thanks!
Veenit Kumar
