Hello pgRouting community,
The pgRouting Team is pleased to announce the release of pgRouting version 3.5.0
The latest release is available at [1]
For discussions on the release, go to [2]
To see all issues & pull requests closed by this release, see the Git closed milestone for 3.5.0 on Github. [3]
Official functions changes
- Dijkstra
- Standarizing output columns to |short-generic-result|
- pgr_dijkstra (One to One) added start_vid and end_vid columns.
- pgr_dijkstra (One to Many) added end_vid column.
- pgr_dijkstra (Many to One) added start_vid column.
To update your database
Download the packaged version from your operating system, and use this command in the database:
ALTER EXTENSION pgrouting UPDATE TO “3.5.0”;
[1]. https://github.com/pgRouting/pgrouting/releases/latest
[2]. https://github.com/pgRouting/pgrouting/discussions/2483
[3]. https://github.com/pgRouting/pgrouting/issues?utf8=%E2%9C%93&q=milestone%3A%22Release%203.5.0%22
pgRouting Team.
Thanks Ashish
On Tue, Mar 7, 2023 at 10:57 PM Ashish Kumar <ashishkr23438@gmail.com> wrote:
- Dijkstra
pgRouting Team.
pgrouting-dev mailing list
pgrouting-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Great news! Thanks, Ashish and the pgRouting team.
Best regards,
Rajat
On Wed, Mar 8, 2023 at 11:37 PM Vicky Vergara <vicky@erosion.dev> wrote:
Thanks Ashish
- Dijkstra
pgRouting Team.
Hello all,
Last changes done on the repository because of the 3.5.0 release.
branch
branch main: has been pumped up to 3.5.1 ready to have internal code improvements and or bug fixes and/or documentation improvements. for bug fixes, the release will be made ASAp, otherwise we will wait a little to see if some code improvements and/or documentation improvements show up.
branch develop: has been pumped up to 3.6.0 ready to forward port changes on branch main and/or add new functionality
branch dev-4.0: is ready to forward port changes on branch develop, it already has changes happening
If you make a PR to main, that is, there is no new functionality (see above), please also make a PR to develop
On main & develop: when possible: PR will be squashed. (weblate’s PR are rebased)
GSoC participant’s PR (on develop): will be rebased.
Changes from develop into dev-4.0 will be capture manually, by rebasing develop and fixing conflicts, so please do not make a PR to dev-4.0 unless is an actual change on 4.0
Regards
Vicky
On Thu, Mar 9, 2023 at 10:53 AM Rajat Shinde <rajatshinde2303@gmail.com> wrote:
Best regards,
Rajat
Thanks Ashish
- Dijkstra
pgRouting Team.
