I’ve just put on EDB Stackbuilder the PostGIS 3.0.2 windows installer for PostgreSQL 13 so you should see a Spatial Extensions section now
You can also find installers and binaries on OSGeo download
https://download.osgeo.org/postgis/windows/pg13/
As mentioned earlier, this set has newer libraries than the PostGIS 3.0.2 of older versions. I do plan on the next micro to have all PostgreSQL versions using these newer GDAL and proj libraries. Possibly even newer than what is packaged in these
What is included is as follows:
PostGIS 3.0.2 (includes postgis, postgis_raster, postgis_sfcgal, postgis_topology, postgis_tiger_geocoder, and address_standardizer extensions) - https://postgis.net/2020/08/15/postgis-patches/
GDAL 3.0.4, Proj 6.3.2, GEOS 3.8.1 (prior PostGIS 3.0.2 releases had proj 5.2.0 and GDAL 2.4.4), MVT support
Ogrfdw 1.0.12 - https://github.com/pramsey/pgsql-ogr-fdw/releases/tag/v1.0.12
pgRouting 3.1.0 - https://docs.pgrouting.org/3.1/en/release_notes.html#changelog-3-1-0
pgPointcloud 1.2.1 - https://github.com/pgpointcloud/pointcloud/releases/tag/v1.2.1
Please report any issues on this mailing list. pgRouting specific issues should be reported on the pgRouting list (also cc’d here)
Regina
