[pgrouting-dev] Travis Tests
Here are the latest results from Travis. Looks like we have some probelms to look at.
-Steve
  222.1 4 min 34 sec 37 minutes ago gcc POSTGRESQL_VERSION=9.0 POSTGIS_VERSION=1.5
  List of databases
Name | Owner | Encoding | Collation | Ctype | Access privileges
postgres | postgres | UTF8 | en_US.UTF-8 | en_US.UTF-8 |
template0 | postgres | UTF8 | en_US.UTF-8 | en_US.UTF-8 | =c/postgres +
| | | | | postgres=CTc/postgres
template1 | postgres | UTF8 | en_US.UTF-8 | en_US.UTF-8 | =c/postgres +
template_pgrouting | postgres | UTF8 | en_US.UTF-8 | en_US.UTF-8 |
template_postgis | postgres | UTF8 | en_US.UTF-8 | en_US.UTF-8 |
(5 rows)
postgis_full_version
POSTGIS="1.5.8" GEOS="3.3.3-CAPI-1.7.4" PROJ="Rel. 4.7.1, 23 September 2009" LIBXML="2.7.8" USE_STATS
(1 row)
pgr_version
(2.0.0-dev,v2.0.0-rc1,105,592406b,develop,1.46.1)
(1 row)
RUNNING: test-runner.pl -pgver 9.0 -ignorenotice
CREATE TYPE
CREATE TYPE
CREATE TYPE
CREATE FUNCTION
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
Processing test: sampledata
test run time: 0.121367
Processing test: alphashape-any
test run time: 0.119769
Processing test: apspJohnson-any
test run time: 0.090964
Processing test: apspWarshall-any
test run time: 0.092882
Processing test: astar-any
test run time: 0.095164
Processing test: bdstar-any
test run time: 0.165799
Processing test: bdDijkstra-any
test run time: 0.08911
Processing test: dijkstra-any
test run time: 0.090361
Processing test: drivingDistance-any
test run time: 0.185142
Processing test: pointsAsPolygon-any
test run time: 0.110968
Processing test: kdijkstra-any
test run time: 0.11264
Processing test: tsp-any
test run time: 0.146337
Processing test: trsp-any
test run time: 0.171032
Processing test: utilities-any
test run time: 0.097965
Processing test: createTopology-any
test run time: 0.278492
Processing test: createVertTab-any
test run time: 0.254425
Processing test: analyzeGraph-any
test run time: 0.306432
Processing test: analyzeOneway-any
test run time: 0.100425
Processing test: nodeNetwork-any
test run time: 0.140351
Processing test: tsp-any-00
test run time: 0.14312
Processing test: tsp-any-01
test run time: 0.124345
Processing test: tsp-any-02
test run time: 0.107115
Processing test: tsp-any-03
test run time: 0.143937
Processing test: tsp-any-04
test run time: 0.118893
Processing test: tsp-any-05
test run time: 0.141214
Processing test: spas-any-00
test run time: 0.089751
Processing test: spas-any-01
test run time: 0.088304
Processing test: bd_dijkstra-any-01
test run time: 0.11406
Processing test: bd_dijkstra-any-02
test run time: 0.124279
Processing test: bd_dijkstra-any-03
test run time: 0.113608
Processing test: bd_dijkstra-any-04
test run time: 0.112199
Processing test: bd_dijkstra-any-05
test run time: 0.114427
Processing test: bd_dijkstra-any-06
test run time: 0.125219
Processing test: kdijkstra-any-01
test run time: 0.091831
Processing test: kdijkstra-any-02
test run time: 0.089681
Processing test: kdijkstra-any-03
test run time: 0.0909720000000001
Processing test: apsp_johnson-any-00
test run time: 0.091335
Processing test: trsp-any-00
test run time: 0.089759
Processing test: trsp-any-01
test run time: 0.088253
Processing test: trsp-any-02
test run time: 0.091135
Processing test: trsp-any-03
test run time: 0.09567
Processing test: ksp-any-01
test run time: 0.093306
Processing test: ksp-any-02
test run time: 0.092821
Processing test: versionless-any-01
test run time: 0.179202
Processing test: common-any-01
test run time: 0.208923
Processing test: common-any-02
test run time: 0.248724
Processing test: common-any-03
test run time: 0.221378
Processing test: common-any-04
test run time: 0.579084
Processing test: common-any-05
test run time: 0.426877
Processing test: createTopology-any-01
test run time: 4.26585
Processing test: createVerticesTable-any-01
test run time: 4.337106
Processing test: gettablename-any-01
test run time: 1.218954
Processing test: spd-any-00
test run time: 0.15279
Processing test: spd-any-01
test run time: 0.114872
Processing test: spd-any-02
test run time: 0.137797
Processing test: spd-any-03
test run time: 0.128846
Processing test: spd-any-04
test run time: 0.101119
Processing test: apsp_warshall-any-00
test run time: 0.107994
Processing test: drivingdistance-any-00
test run time: 0.194654
Processing test: bd_astar-any-01
test run time: 0.116986
Processing test: bd_astar-any-02
test run time: 0.121284
Processing test: bd_astar-any-03
test run time: 0.135156
Processing test: bd_astar-any-04
test run time: 0.109259
Processing test: bd_astar-any-05
test run time: 0.12025
Processing test: bd_astar-any-06
test run time: 0.133238
$stats = {
'doc/test/test.conf' => [
'comment' => 'documentation SQL tests for any versions.',
'doc/test/alphashape-any.test' => 'FAILED: 7,14c7,10
< 0.5|3.5
< 0|2
< 2|0
< 4|1
< 4|2
< 4|3
< 3.5|4
< 2|4
> ERROR: relation "edge_table_vertices_pgr" does not exist
> LINE 1: ...om)::float as x, st_y(the_geom)::float as y FROM edge_table...
> QUERY: SELECT id::integer, st_x(the_geom)::float as x, st_y(the_geom)::float as y FROM edge_table_vertices_pgr',
'doc/test/analyzeGraph-any.test' => 'FAILED: 1,28c1,31
< OK
< OK
< OK
< FAIL
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> ERROR: relation "edge_table" does not exist
> LINE 1: ...e AS src ,target AS tgt , the_geom AS mygeom FROM edge_table...
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL',
'doc/test/analyzeOneway-any.test' => 'FAILED: 1c1
< OK
> FAIL',
'doc/test/apspJohnson-any.test' => 'FAILED: 1,10c1,4
< 0|1|1|0
< 1|1|2|1
< 2|1|5|2
< 3|1|6|3
< 4|1|9|4
< 5|1|10|3
< 6|1|11|4
< 7|1|12|5
< 8|1|13|4
< 9|2|2|0
> LINE 1: SELECT source, target, cost FROM edge_table
> QUERY: SELECT source, target, cost FROM edge_table',
'doc/test/apspWarshall-any.test' => 'FAILED: 1,10c1,4
< 0|1|1|0
< 1|1|2|1
< 2|1|3|0
< 3|1|4|-1
< 4|1|5|2
< 5|1|6|1
< 6|1|11|2
< 7|1|10|3
< 8|1|12|1
< 9|1|13|4
> LINE 1: SELECT id, source, target, cost FROM edge_table
> QUERY: SELECT id, source, target, cost FROM edge_table',
'doc/test/astar-any.test' => 'FAILED: 1,10c1,8
< 0|4|16|1
< 1|9|9|1
< 2|6|8|1
< 3|5|10|1
< 4|10|-1|0
< 0|4|3|1
< 1|3|2|1
< 2|2|4|1
< 3|5|10|1
< 4|10|-1|0
> LINE 1: ...ECT id, source, target, cost, x1, y1, x2, y2 FROM edge_table...
> QUERY: SELECT id, source, target, cost, x1, y1, x2, y2 FROM edge_table order by id
> LINE 1: ..., target, cost, x1, y1, x2, y2, reverse_cost FROM edge_table...
> QUERY: SELECT id, source, target, cost, x1, y1, x2, y2, reverse_cost FROM edge_table',
'doc/test/bdDijkstra-any.test' => 'FAILED: 1,12c1,8
< 0|7|6|1
< 1|8|7|1
< 2|5|8|1
< 3|6|9|1
< 4|9|15|1
< 5|12|-1|0
< 0|7|6|1
< 1|8|7|1
< 2|5|8|1
< 3|6|9|1
< 4|9|15|1
< 5|12|-1|0
> LINE 1: SELECT id, source, target, cost FROM edge_table order by id
> QUERY: SELECT id, source, target, cost FROM edge_table order by id
> LINE 1: ...ELECT id, source, target, cost, reverse_cost FROM edge_table
> QUERY: SELECT id, source, target, cost, reverse_cost FROM edge_table',
'doc/test/bdstar-any.test' => 'FAILED: 1,10c1,8
< 0|4|3|0
< 1|3|5|1
< 2|6|11|1
< 3|11|12|0
< 4|10|-1|0
< 0|4|3|1
< 1|3|5|1
< 2|6|8|1
< 3|5|10|1
< 4|10|-1|0
'doc/test/createTopology-any.test' => 'FAILED: 1,2d0
< OK
< OK
4,21c2,24
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> LINE 1: ..._geom AS mygeom,source AS src ,target AS tgt FROM edge_table...
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL',
'doc/test/createVertTab-any.test' => 'FAILED: 1,2d0
< OK
< OK
4,20c2,23
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL',
'doc/test/dijkstra-any.test' => 'FAILED: 1,12c1,8
< 0|7|6|1
< 1|8|7|1
< 2|5|8|1
< 3|6|9|1
< 4|9|15|1
< 5|12|-1|0
< 0|7|6|1
< 1|8|7|1
< 2|5|8|1
< 3|6|9|1
< 4|9|15|1
< 5|12|-1|0
'doc/test/drivingDistance-any.test' => 'FAILED: 1,9c1,8
< 0|3|1
< 1|5|1
< 2|6|0
< 3|9|1
< 4|11|1
< 0|5|1
< 1|6|0
< 2|9|1
< 3|11|1
'doc/test/kdijkstra-any.test' => 'FAILED: 1,12c1,11
< 0|10|4|4
< 1|10|12|2
< 0|4|10|12|1
< 1|4|11|13|1
< 2|4|12|15|1
< 3|4|9|16|1
< 4|4|4|-1|0
< 5|12|10|12|1
< 6|12|11|13|1
< 7|12|12|-1|0
< 4|LINESTRING(2 3,3 3,4 3,4 2,4 1)
< 12|LINESTRING(2 3,3 3,4 3)
> LINE 6: edge_table b
'doc/test/nodeNetwork-any.test' => 'FAILED: 1,30c1,17
< OK
< OK
< OK
< 1|1
< 2|1
< 3|1
< 4|1
< 5|1
< 6|1
< 7|1
< 8|1
< 9|1
< 10|1
< 11|1
< 12|1
< 13|1
< 13|2
< 14|1
< 14|2
< 15|1
< 16|1
< 17|1
< 18|1
< 18|2
< OK
< OK
< OK
< OK
< OK
< OK
> FAIL
> FAIL
> FAIL
> ERROR: relation "edge_table_noded" does not exist
> LINE 1: SELECT old_id,sub_id FROM edge_table_noded ORDER BY old_id,s...
> FAIL
> FAIL
> LINE 1: insert into edge_table (old_id,dir,cost,reverse_cost,the_geo...
> FAIL
> FAIL
> FAIL
> FAIL',
'doc/test/pointsAsPolygon-any.test' => 'FAILED: 2c2,6
< POLYGON((0.5 3.5,0 2,2 0,4 1,4 2,4 3,3.5 4,2 4,0.5 3.5))
> CONTEXT: PL/pgSQL function "pgr_pointsaspolygon" line 13 at FOR over EXECUTE statement',
'doc/test/sampledata.test' => 'FAILED: 1c1,61
< OK
> ERROR: type modifier is not allowed for type "geometry"
> LINE 12: the_geom geometry(Linestring)
> LINE 1: INSERT INTO edge_table (cost,reverse_cost,x1,y1,x2,y2) VALUE...
> LINE 1: UPDATE edge_table SET the_geom = st_makeline(st_point(x1,y1)...
> FAIL',
'doc/test/trsp-any.test' => 'FAILED: 1,12c1,8
< 0|7|6|1
< 1|8|7|1
< 2|5|8|1
< 3|6|11|1
< 4|11|13|1
< 5|12|-1|0
< 0|7|6|1
< 1|8|7|1
< 2|5|8|1
< 3|6|11|1
< 4|11|13|1
< 5|12|-1|0
'doc/test/tsp-any.test' => 'FAILED: 3,12c3,12
< 2|1|2|1.00
< 3|0|1|1.41
< 4|2|3|1.00
< 5|7|8|1.41
< 6|3|4|1.00
< 7|8|9|1.00
< 8|11|12|1.00
< 9|10|11|1.41
< 10|12|13|1.00
< 11|9|10|2.24
> 2|9|10|1.00
> 3|12|13|1.41
> 4|10|11|1.00
> 5|11|12|1.00
> 6|8|9|1.00
> 7|3|4|1.41
> 8|7|8|1.00
> 9|2|3|1.41
> 10|0|1|1.00
> 11|1|2|2.24
22,38c22,32
< 0|5|6|1.41
< 1|3|4|0.00
< 2|11|12|0.00
< 3|8|9|0.71
< 4|16|17|0.00
< 5|15|16|0.71
< 6|2|3|0.00
< 7|10|11|1.41
< 8|1|2|0.00
< 9|12|13|2.12
< 10|13|14|0.71
< 11|6|7|1.41
< 12|7|8|1.41
< 13|9|10|0.00
< 14|0|1|0.00
< 15|14|15|0.00
< 16|4|5|1.41
> LINE 1: ...ger, st_x(the_geom) as x,st_x(the_geom) as y FROM edge_table...
> QUERY: with nodes as (SELECT id::integer, st_x(the_geom) as x,st_x(the_geom) as y FROM edge_table_vertices_pgr ORDER BY id)
> select i, array_agg(dist) as arow from (
> select a.id as i, b.id as j, st_distance(st_makepoint(a.x, a.y), st_makepoint(b.x, b.y)) as dist
> from nodes a, nodes b
> order by a.id, b.id
> ) as foo group by i order by i
> CONTEXT: PL/pgSQL function "pgr_makedistancematrix" line 16 at FOR over EXECUTE statement
> PL/pgSQL function "pgr_tsp" line 7 at RETURN QUERY',
'doc/test/utilities-any.test' => 'Passed'
'src/apsp_johnson/test/test.conf' => [
'comment' => 'APSP Johnson test for any versions.',
'src/apsp_johnson/test/apsp_johnson-any-00.test' => 'Passed'
'src/apsp_warshall/test/test.conf' => [
'comment' => 'APSP Warshall test for any versions.',
'src/apsp_warshall/test/apsp_warshall-any-00.test' => 'Passed'
'src/astar/test/test.conf' => [
'comment' => 'astar test for any versions.',
'src/astar/test/spas-any-00.test' => 'Passed',
'src/astar/test/spas-any-01.test' => 'Passed'
'src/bd_astar/test/test.conf' => [
'comment' => 'Bi-directional AStar test for any versions.',
'src/bd_astar/test/bd_astar-any-01.test' => 'Passed',
'src/bd_astar/test/bd_astar-any-02.test' => 'Passed',
'src/bd_astar/test/bd_astar-any-03.test' => 'Passed',
'src/bd_astar/test/bd_astar-any-04.test' => 'Passed',
'src/bd_astar/test/bd_astar-any-05.test' => 'Passed',
'src/bd_astar/test/bd_astar-any-06.test' => 'Passed'
'src/bd_dijkstra/test/test.conf' => [
'comment' => 'Bi-directional Dijkstra test for any versions.',
'src/bd_dijkstra/test/bd_dijkstra-any-01.test' => 'Passed',
'src/bd_dijkstra/test/bd_dijkstra-any-02.test' => 'Passed',
'src/bd_dijkstra/test/bd_dijkstra-any-03.test' => 'Passed',
'src/bd_dijkstra/test/bd_dijkstra-any-04.test' => 'Passed',
'src/bd_dijkstra/test/bd_dijkstra-any-05.test' => 'Passed',
'src/bd_dijkstra/test/bd_dijkstra-any-06.test' => 'Passed'
'src/common/test/test.conf' => [
'comment' => 'pgr_createTopology, pgr_analyzegraph, and pgr_analyzeOneway tests for any versions.',
'src/common/test/common-any-01.test' => 'Passed',
'src/common/test/common-any-02.test' => 'FAILED: 2,3c2,17
< OK
< 1
> ERROR: syntax error at or near "update"
> LINE 11: update public.edges2_vertices_pgr as a set cn...
> QUERY: with countingsource as (select a.source as id,count(*) as cnts
> from (select * from public.edges2 where true AND (true) ) a group by a.source)
> ,countingtarget as (select a.target as id,count(*) as cntt
> from (select * from public.edges2 where true AND (true) ) a group by a.target)
> ,totalcount as (select id,case when cnts is null and cntt is null then 0
> when cnts is null then cntt
> when cntt is null then cnts
> else cnts+cntt end as totcnt
> from (public.edges2_vertices_pgr as a left
> join countingsource as t using(id) ) left join countingtarget using(id))
> update public.edges2_vertices_pgr as a set cnt=totcnt from totalcount as b where a.id=b.id
> CONTEXT: PL/pgSQL function "pgr_analyzegraph" line 258 at EXECUTE statement
> 0
5,8c19
< 1|4
< 2|8
< 3|6
< 4|2
> |20
10,29c21,40
< 1|1|0|||010100000000000000000000400000000000000000
< 2|3|0|||01010000000000000000000040000000000000F03F
< 3|3|0|||01010000000000000000000840000000000000F03F
< 4|2|0|||01010000000000000000001040000000000000F03F
< 5|4|0|||010100000000000000000000400000000000000040
< 6|4|0|||010100000000000000000008400000000000000040
< 7|1|0|||010100000000000000000000000000000000000040
< 8|2|0|||0101000000000000000000F03F0000000000000040
< 9|3|0|||010100000000000000000010400000000000000040
< 10|3|0|||010100000000000000000000400000000000000840
< 11|3|0|||010100000000000000000008400000000000000840
< 12|2|0|||010100000000000000000010400000000000000840
< 13|1|0|||010100000000000000000000400000000000001040
< 14|2|0|||0101000000000000000000F03F000000000000E03F
< 15|2|0|||01010000000000000000000040000000000000E03F
< 16|2|0|||01010000000000000000000840000000000000E03F
< 17|2|0|||0101000000000000000000F03F000000000000F83F
< 18|3|0|||0101000000000000000000F03F0000000000000440
< 19|2|0|||0101000000000000000000F03F0000000000000C40
< 20|1|1|||010100000000000000000000400000000000000C40
> 1|||||010100000000000000000000400000000000000000
> 2|||||01010000000000000000000040000000000000F03F
> 3|||||01010000000000000000000840000000000000F03F
> 4|||||01010000000000000000001040000000000000F03F
> 5|||||010100000000000000000000400000000000000040
> 6|||||010100000000000000000008400000000000000040
> 7|||||010100000000000000000000000000000000000040
> 8|||||0101000000000000000000F03F0000000000000040
> 9|||||010100000000000000000010400000000000000040
> 10|||||010100000000000000000000400000000000000840
> 11|||||010100000000000000000008400000000000000840
> 12|||||010100000000000000000010400000000000000840
> 13|||||010100000000000000000000400000000000001040
> 14|||||0101000000000000000000F03F000000000000E03F
> 15|||||01010000000000000000000040000000000000E03F
> 16|||||01010000000000000000000840000000000000E03F
> 17|||||0101000000000000000000F03F000000000000F83F
> 18|||||0101000000000000000000F03F0000000000000440
> 19|||||0101000000000000000000F03F0000000000000C40
> 20|||||010100000000000000000000400000000000000C40',
'src/common/test/common-any-03.test' => 'Passed',
'src/common/test/common-any-04.test' => 'FAILED: 4c4,18
< OK
> LINE 11: update public.unnoded_noded_vertices_pgr as a...
> from (select * from public.unnoded_noded where true AND (true) ) a group by a.source)
> from (select * from public.unnoded_noded where true AND (true) ) a group by a.target)
> from (public.unnoded_noded_vertices_pgr as a left
> update public.unnoded_noded_vertices_pgr as a set cnt=totcnt from totalcount as b where a.id=b.id
45,78c59,99
< 1|1|0|||0101000000000000000000F03F0000000000000040
< 2|4|0|||010100000000000000000000400000000000000040
< 3|4|0|||010100000000000000000008400000000000000040
< 4|4|0|||010100000000000000000010400000000000000040
< 5|4|0|||010100000000000000000014400000000000000040
< 6|1|0|||010100000000000000000018400000000000000040
< 7|1|0|||0101000000000000000000F03F0000000000000840
< 8|4|0|||010100000000000000000000400000000000000840
< 9|4|0|||010100000000000000000008400000000000000840
< 10|4|0|||010100000000000000000010400000000000000840
< 11|4|0|||010100000000000000000014400000000000000840
< 12|1|0|||010100000000000000000018400000000000000840
< 13|1|0|||0101000000000000000000F03F0000000000001040
< 14|4|0|||010100000000000000000000400000000000001040
< 15|4|0|||010100000000000000000008400000000000001040
< 16|4|0|||010100000000000000000010400000000000001040
< 17|4|0|||010100000000000000000014400000000000001040
< 18|1|0|||010100000000000000000018400000000000001040
< 19|1|0|||0101000000000000000000F03F0000000000001440
< 20|4|0|||010100000000000000000000400000000000001440
< 21|4|0|||010100000000000000000008400000000000001440
< 22|4|0|||010100000000000000000010400000000000001440
< 23|4|0|||010100000000000000000014400000000000001440
< 24|1|0|||010100000000000000000018400000000000001440
< 25|1|0|||01010000000000000000000040000000000000F03F
< 26|1|0|||010100000000000000000000400000000000001840
< 27|1|0|||01010000000000000000000840000000000000F03F
< 28|1|0|||010100000000000000000008400000000000001840
< 29|1|0|||01010000000000000000001040000000000000F03F
< 30|1|0|||010100000000000000000010400000000000001840
< 31|1|0|||01010000000000000000001440000000000000F03F
< 32|1|0|||010100000000000000000014400000000000001840
< public.noded2.the_geom SRID:0 TYPE:LINESTRING DIMS:2
< OK
> 1|||||0101000000000000000000F03F0000000000000040
> 2|||||010100000000000000000000400000000000000040
> 3|||||010100000000000000000008400000000000000040
> 4|||||010100000000000000000010400000000000000040
> 5|||||010100000000000000000014400000000000000040
> 6|||||010100000000000000000018400000000000000040
> 7|||||0101000000000000000000F03F0000000000000840
> 8|||||010100000000000000000000400000000000000840
> 9|||||010100000000000000000008400000000000000840
> 10|||||010100000000000000000010400000000000000840
> 11|||||010100000000000000000014400000000000000840
> 12|||||010100000000000000000018400000000000000840
> 13|||||0101000000000000000000F03F0000000000001040
> 14|||||010100000000000000000000400000000000001040
> 15|||||010100000000000000000008400000000000001040
> 16|||||010100000000000000000010400000000000001040
> 17|||||010100000000000000000014400000000000001040
> 18|||||010100000000000000000018400000000000001040
> 19|||||0101000000000000000000F03F0000000000001440
> 20|||||010100000000000000000000400000000000001440
> 21|||||010100000000000000000008400000000000001440
> 22|||||010100000000000000000010400000000000001440
> 23|||||010100000000000000000014400000000000001440
> 24|||||010100000000000000000018400000000000001440
> 25|||||01010000000000000000000040000000000000F03F
> 26|||||010100000000000000000000400000000000001840
> 27|||||01010000000000000000000840000000000000F03F
> 28|||||010100000000000000000008400000000000001840
> 29|||||01010000000000000000001040000000000000F03F
> 30|||||010100000000000000000010400000000000001840
> 31|||||01010000000000000000001440000000000000F03F
> 32|||||010100000000000000000014400000000000001840
> public.noded2.the_geom SRID:-1 TYPE:LINESTRING DIMS:2
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'noded2\',1e-06,\'the_geom\',\'gid\',\'source\',\'target\',\'true\')
> NOTICE: Performing checks, pelase wait .....
> NOTICE: Creating Topology, Please wait...
> NOTICE: -------------> TOPOLOGY CREATED FOR 40 edges
> NOTICE: Rows with NULL geometry or NULL id: 0
> NOTICE: Vertices table for table public.noded2 is: public.noded2_vertices_pgr
> NOTICE: ----------------------------------------------
79a101,127
> NOTICE: PROCESSING:
> NOTICE: pgr_analyzeGraph(\'noded2\',1e-06,\'the_geom\',\'gid\',\'source\',\'target\',\'true\')
> NOTICE: Performing checks, pelase wait...
> NOTICE: Analyzing for dead ends. Please wait...
> LINE 11: update public.noded2_vertices_pgr as a set cn...
> from (select * from public.noded2 where true AND (true) ) a group by a.source)
> from (select * from public.noded2 where true AND (true) ) a group by a.target)
> from (public.noded2_vertices_pgr as a left
> update public.noded2_vertices_pgr as a set cnt=totcnt from totalcount as b where a.id=b.id
> NOTICE: PROCESSING:
> NOTICE: pgr_analyzeOneway(\'noded2\',\'{"",B,TF}\',\'{"",B,FT}\',\'{"",B,FT}\',\'{"",B,TF}\',\'dir\',\'source\',\'target\',t)
> NOTICE: Analyzing graph for one way street errors.
> NOTICE: Analysis 25% complete ...
> NOTICE: Analysis 50% complete ...
> NOTICE: Analysis 75% complete ...
> NOTICE: Analysis 100% complete ...
> NOTICE: Found 16 potential problems in directionality
121,152c169,200
< 1|1|0|0|1|0101000000000000000000F03F0000000000000040
< 2|4|0|2|2|010100000000000000000000400000000000000040
< 3|4|0|2|2|010100000000000000000008400000000000000040
< 4|4|0|2|2|010100000000000000000010400000000000000040
< 5|4|0|2|2|010100000000000000000014400000000000000040
< 6|1|0|1|0|010100000000000000000018400000000000000040
< 7|1|0|1|0|0101000000000000000000F03F0000000000000840
< 8|4|0|2|2|010100000000000000000000400000000000000840
< 9|4|0|2|2|010100000000000000000008400000000000000840
< 10|4|0|2|2|010100000000000000000010400000000000000840
< 11|4|0|2|2|010100000000000000000014400000000000000840
< 12|1|0|0|1|010100000000000000000018400000000000000840
< 13|1|0|0|1|0101000000000000000000F03F0000000000001040
< 14|4|0|2|2|010100000000000000000000400000000000001040
< 15|4|0|2|2|010100000000000000000008400000000000001040
< 16|4|0|2|2|010100000000000000000010400000000000001040
< 17|4|0|2|2|010100000000000000000014400000000000001040
< 18|1|0|1|0|010100000000000000000018400000000000001040
< 19|1|0|1|0|0101000000000000000000F03F0000000000001440
< 20|4|0|2|2|010100000000000000000000400000000000001440
< 21|4|0|2|2|010100000000000000000008400000000000001440
< 22|4|0|2|2|010100000000000000000010400000000000001440
< 23|4|0|2|2|010100000000000000000014400000000000001440
< 24|1|0|0|1|010100000000000000000018400000000000001440
< 25|1|0|0|1|01010000000000000000000040000000000000F03F
< 26|1|0|1|0|010100000000000000000000400000000000001840
< 27|1|0|1|0|01010000000000000000000840000000000000F03F
< 28|1|0|0|1|010100000000000000000008400000000000001840
< 29|1|0|0|1|01010000000000000000001040000000000000F03F
< 30|1|0|1|0|010100000000000000000010400000000000001840
< 31|1|0|1|0|01010000000000000000001440000000000000F03F
< 32|1|0|0|1|010100000000000000000014400000000000001840
> 1|||0|1|0101000000000000000000F03F0000000000000040
> 2|||2|2|010100000000000000000000400000000000000040
> 3|||2|2|010100000000000000000008400000000000000040
> 4|||2|2|010100000000000000000010400000000000000040
> 5|||2|2|010100000000000000000014400000000000000040
> 6|||1|0|010100000000000000000018400000000000000040
> 7|||1|0|0101000000000000000000F03F0000000000000840
> 8|||2|2|010100000000000000000000400000000000000840
> 9|||2|2|010100000000000000000008400000000000000840
> 10|||2|2|010100000000000000000010400000000000000840
> 11|||2|2|010100000000000000000014400000000000000840
> 12|||0|1|010100000000000000000018400000000000000840
> 13|||0|1|0101000000000000000000F03F0000000000001040
> 14|||2|2|010100000000000000000000400000000000001040
> 15|||2|2|010100000000000000000008400000000000001040
> 16|||2|2|010100000000000000000010400000000000001040
> 17|||2|2|010100000000000000000014400000000000001040
> 18|||1|0|010100000000000000000018400000000000001040
> 19|||1|0|0101000000000000000000F03F0000000000001440
> 20|||2|2|010100000000000000000000400000000000001440
> 21|||2|2|010100000000000000000008400000000000001440
> 22|||2|2|010100000000000000000010400000000000001440
> 23|||2|2|010100000000000000000014400000000000001440
> 24|||0|1|010100000000000000000018400000000000001440
> 25|||0|1|01010000000000000000000040000000000000F03F
> 26|||1|0|010100000000000000000000400000000000001840
> 27|||1|0|01010000000000000000000840000000000000F03F
> 28|||0|1|010100000000000000000008400000000000001840
> 29|||0|1|01010000000000000000001040000000000000F03F
> 30|||1|0|010100000000000000000010400000000000001840
> 31|||1|0|01010000000000000000001440000000000000F03F
> 32|||0|1|010100000000000000000014400000000000001840',
'src/common/test/common-any-05.test' => 'FAILED: 1c1
< public.noded3.the_geom SRID:0 TYPE:MULTILINESTRING DIMS:2
> public.noded3.the_geom SRID:-1 TYPE:MULTILINESTRING DIMS:2
2a3,10
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'noded3\',1e-06,\'the_geom\',\'gid\',\'source\',\'target\',\'true\')
> NOTICE: Vertices table for table public.noded3 is: public.noded3_vertices_pgr
> NOTICE: ----------------------------------------------',
'src/common/test/createTopology-any-01.test' => 'FAILED: 1,65c1,500
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< OK
< OK
< OK
< FAIL
< FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'edges2\',1e-06,\'the_geom\',\'eid\',\'source\',\'target\',\'true\')
> NOTICE: -------------> TOPOLOGY CREATED FOR 23 edges
> NOTICE: Vertices table for table public.edges2 is: public.edges2_vertices_pgr
> OK
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'Edges2\',1e-06,\'the_geom\',\'eid\',\'source\',\'target\',\'true\')
> OK
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'edges2\',1e-06,\'The_Geom\',\'eid\',\'source\',\'target\',\'true\')
> OK
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'edges2\',1e-06,\'the_geom\',\'Eid\',\'source\',\'target\',\'true\')
> OK
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'edges2\',1e-06,\'The_geom\',\'Eid\',\'source\',\'target\',\'true\')
> OK
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'Edges2\',1e-06,\'The_geom\',\'Eid\',\'source\',\'target\',\'true\')
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'edges2\',1e-06,\'the_geom\',\'eid\',\'Source\',\'target\',\'true\')
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'edges2\',1e-06,\'the_geom\',\'eid\',\'source\',\'target\',\'eid<15\')
> NOTICE: -------------> TOPOLOGY CREATED FOR 14 edges
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'edges2\',1e-06,\'the_geom\',\'eid\',\'source\',\'target\',\'eid<15 and eid>5\')
> NOTICE: -------------> TOPOLOGY CREATED FOR 9 edges
> OK
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'edges22\',1e-06,\'the_geom\',\'eid\',\'source\',\'target\',\'true\')
> NOTICE: -------> edges22 not found
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'edges2\',1e-06,\'geom\',\'eid\',\'source\',\'target\',\'true\')
> NOTICE: ERROR: Geometry column "geom" not found in public.edges2
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'edges2\',1e-06,\'the_geom\',\'gid\',\'source\',\'target\',\'true\')
> NOTICE: ERROR: id column "gid" not found in public.edges2
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'edges2\',1e-06,\'the_geom\',\'eid\',\'sourc\',\'target\',\'true\')
> NOTICE: ERROR: source column "sourc" not found in public.edges2
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'edges2\',1e-06,\'the_geom\',\'eid\',\'source\',\'source\',\'true\')
> NOTICE: ERROR: source and target columns have the same name "source" in public.edges2
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'edges2\',1e-06,\'the_geom\',\'eid\',\'the_geom\',\'target\',\'true\')
> NOTICE: ERROR: source column "the_geom" is not of integer type
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'edges2\',1e-06,\'the_geom\',\'eid\',\'source\',\'the_geom\',\'true\')
> NOTICE: ERROR: target column "the_geom" is not of integer type
> FAIL
> NOTICE: PROCESSING:
> NOTICE: Vertices table for table public."Edges2" is: public."Edges2_vertices_pgr"
> OK
> NOTICE: PROCESSING:
> NOTICE: -------------> TOPOLOGY CREATED FOR 22 edges
> NOTICE: Rows with NULL geometry or NULL id: 1
> OK
> NOTICE: PROCESSING:
> NOTICE: -------------> TOPOLOGY CREATED FOR 21 edges
> NOTICE: Rows with NULL geometry or NULL id: 2
> OK
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'public.edges2\',1e-06,\'the_geom\',\'eid\',\'source\',\'target\',\'true\')
> OK
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'public.Edges2\',1e-06,\'the_geom\',\'eid\',\'source\',\'target\',\'true\')
> OK
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'Public.edges2\',1e-06,\'The_Geom\',\'eid\',\'source\',\'target\',\'true\')
> OK
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'public.edges2\',1e-06,\'the_geom\',\'Eid\',\'source\',\'target\',\'true\')
> OK
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'public.edges2\',1e-06,\'The_geom\',\'Eid\',\'source\',\'target\',\'true\')
> OK
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'PUBLIC.Edges2\',1e-06,\'The_geom\',\'Eid\',\'source\',\'target\',\'true\')
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'public.edges2\',1e-06,\'the_geom\',\'eid\',\'Source\',\'target\',\'true\')
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'public.edges2\',1e-06,\'the_geom\',\'eid\',\'source\',\'target\',\'eid<15\')
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'public.edges22\',1e-06,\'the_geom\',\'eid\',\'source\',\'target\',\'true\')
> NOTICE: -------> public.edges22 not found
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'public.edges2\',1e-06,\'geom\',\'eid\',\'source\',\'target\',\'true\')
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'public.edges2\',1e-06,\'the_geom\',\'gid\',\'source\',\'target\',\'true\')
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'public.Edges2\',1e-06,\'the_geom\',\'eid\',\'sourc\',\'target\',\'true\')
> NOTICE: ERROR: source column "sourc" not found in public.Edges2
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'public.edges2\',1e-06,\'the_geom\',\'eid\',\'source\',\'source\',\'true\')
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'public.edges2\',1e-06,\'the_geom\',\'eid\',\'the_geom\',\'target\',\'true\')
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'public.edges2\',1e-06,\'the_geom\',\'eid\',\'source\',\'the_geom\',\'true\')
> FAIL
> NOTICE: PROCESSING:
> NOTICE: Vertices table for table myschema.edges2 is: myschema.edges2_vertices_pgr
> OK
> NOTICE: PROCESSING:
> NOTICE: Vertices table for table myschema."Edges2" is: myschema."Edges2_vertices_pgr"
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> NOTICE: ERROR: Geometry column "geom" not found in myschema.edges2
> FAIL
> NOTICE: PROCESSING:
> NOTICE: ERROR: id column "gid" not found in myschema.edges2
> FAIL
> NOTICE: PROCESSING:
> NOTICE: ERROR: source column "sourc" not found in myschema.edges2
> FAIL
> NOTICE: PROCESSING:
> NOTICE: ERROR: source and target columns have the same name "source" in myschema.edges2
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'Edges2\',1e-06,\'the_geom\',\'eid\',\'source\',\'target\',\'eid<15 and eid>5\')
> NOTICE: -------------> TOPOLOGY CREATED FOR 8 edges
> OK
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'Edges2\',1e-06,\'the_geom\',\'eid\',\'source\',\'target\',\' the_geom && (select st_buffer(the_geom,0.0001) as buffer from "Edges2" where eid=6)\')
> NOTICE: -------------> TOPOLOGY CREATED FOR 3 edges
> OK
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'edges2\',1e-06,\'the_geom\',\'eid\',\'source\',\'target\',\'eid<\')
> NOTICE: ERROR: Condition is not correct, please execute the following query to test your condition
> NOTICE: select * from myschema.edges2 WHERE true AND (eid<) limit 1
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'Edges2\',1e-06,\'the_geom\',\'eid\',\'source\',\'target\',\'eid<15 and ed>5\')
> NOTICE: select * from myschema."Edges2" WHERE true AND (eid<15 and ed>5) limit 1
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'Edges2\',1e-06,\'the_geom\',\'eid\',\'source\',\'target\',\' the_geom && (select st_buffer(the_geom,0.0001 as buffer from "Edges2" where eid=6)\')
> NOTICE: select * from myschema."Edges2" WHERE true AND ( the_geom && (select st_buffer(the_geom,0.0001 as buffer from "Edges2" where eid=6)) limit 1',
'src/common/test/createVerticesTable-any-01.test' => 'FAILED: 1,61c1,897
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< OK
< OK
> NOTICE: PROCESSING:
> NOTICE: pgr_createTopology(\'edges2\',1e-05,\'the_geom\',\'eid\',\'source\',\'target\',\'true\')
> OK
> NOTICE: table "edges2_vertex_pgr" does not exist, skipping
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'edges2\',\'the_geom\',\'source\',\'target\',\'true\')
> NOTICE: Populating public.edges2_vertices_pgr, please wait...
> ERROR: syntax error at or near "insert"
> LINE 12: insert into public.edges2_vertices_pgr(id,the_geom) (sele...
> QUERY: with
> lines as ((select distinct source as id, pgr_startpoint(st_linemerge(the_geom)) as the_geom from public.edges2 where (the_geom IS NULL
> or source is null
> or target is null)=false
> AND (true))
> union (select distinct target as id,pgr_endpoint(st_linemerge(the_geom)) as the_geom from public.edges2 where (the_geom IS NULL
> or source is null
> AND (true)))
> ,numberedLines as (select row_number() OVER (ORDER BY id) AS i,* from lines )
> ,maxid as (select id,max(i) as maxi from numberedLines group by id)
> insert into public.edges2_vertices_pgr(id,the_geom) (select id,the_geom from numberedLines join maxid using(id) where i=maxi order by id)
> CONTEXT: PL/pgSQL function "pgr_createverticestable" line 207 at EXECUTE statement
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'Edges2\',\'the_geom\',\'source\',\'target\',\'true\')
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'edges2\',\'The_Geom\',\'source\',\'target\',\'true\')
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'edges2\',\'The_geom\',\'source\',\'target\',\'true\')
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'Edges2\',\'The_geom\',\'source\',\'target\',\'true\')
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'edges2\',\'the_geom\',\'Source\',\'target\',\'true\')
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'edges2\',\'the_geom\',\'source\',\'target\',\'eid<15\')
> QUERY: with
> or source is null
> AND (eid<15))
> or source is null
> AND (eid<15)))
> NOTICE: PROCESSING:
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'edges2\',\'the_geom\',\'source\',\'target\',\'eid<15 and eid>5\')
> QUERY: with
> or source is null
> AND (eid<15 and eid>5))
> or source is null
> AND (eid<15 and eid>5)))
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'edges22\',\'the_geom\',\'source\',\'target\',\'true\')
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'edges2\',\'geom\',\'source\',\'target\',\'true\')
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'edges2\',\'the_geom\',\'gid\',\'target\',\'true\')
> NOTICE: ERROR: source column "gid" not found in public.edges2
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'edges2\',\'the_geom\',\'sourc\',\'target\',\'true\')
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'edges2\',\'the_geom\',\'source\',\'source\',\'true\')
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'edges2\',\'the_geom\',\'the_geom\',\'target\',\'true\')
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'edges2\',\'the_geom\',\'source\',\'the_geom\',\'true\')
> FAIL
> NOTICE: PROCESSING:
> NOTICE: Populating public.Edges2_vertices_pgr, please wait...
> LINE 12: insert into public."Edges2_vertices_pgr"(id,the_geom) (se...
> QUERY: with
> lines as ((select distinct source as id, pgr_startpoint(st_linemerge(the_geom)) as the_geom from public."Edges2" where (the_geom IS NULL
> or source is null
> AND (true))
> union (select distinct target as id,pgr_endpoint(st_linemerge(the_geom)) as the_geom from public."Edges2" where (the_geom IS NULL
> or source is null
> AND (true)))
> insert into public."Edges2_vertices_pgr"(id,the_geom) (select id,the_geom from numberedLines join maxid using(id) where i=maxi order by id)
> NOTICE: PROCESSING:
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'public.edges2\',\'the_geom\',\'source\',\'target\',\'true\')
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'public.Edges2\',\'the_geom\',\'source\',\'target\',\'true\')
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'Public.edges2\',\'The_Geom\',\'source\',\'target\',\'true\')
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'public.edges2\',\'The_geom\',\'source\',\'target\',\'true\')
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'PUBLIC.Edges2\',\'The_geom\',\'source\',\'target\',\'true\')
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'public.edges2\',\'the_geom\',\'Source\',\'target\',\'true\')
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'public.edges2\',\'the_geom\',\'source\',\'target\',\'eid<15\')
> QUERY: with
> or source is null
> AND (eid<15))
> or source is null
> AND (eid<15)))
> NOTICE: PROCESSING:
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> QUERY: with
> or source is null
> AND (eid<15))
> or source is null
> AND (eid<15)))
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'public.edges22\',\'the_geom\',\'source\',\'target\',\'true\')
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'public.edges2\',\'geom\',\'source\',\'target\',\'true\')
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'public.edges2\',\'the_geom\',\'gid\',\'target\',\'true\')
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'public.Edges2\',\'the_geom\',\'sourc\',\'target\',\'true\')
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'public.edges2\',\'the_geom\',\'source\',\'source\',\'true\')
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'public.edges2\',\'the_geom\',\'the_geom\',\'target\',\'true\')
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'public.edges2\',\'the_geom\',\'source\',\'the_geom\',\'true\')
> FAIL
> NOTICE: PROCESSING:
> NOTICE: Populating myschema.edges2_vertices_pgr, please wait...
> LINE 12: insert into myschema.edges2_vertices_pgr(id,the_geom) (se...
> QUERY: with
> lines as ((select distinct source as id, pgr_startpoint(st_linemerge(the_geom)) as the_geom from myschema.edges2 where (the_geom IS NULL
> or source is null
> AND (true))
> union (select distinct target as id,pgr_endpoint(st_linemerge(the_geom)) as the_geom from myschema.edges2 where (the_geom IS NULL
> or source is null
> AND (true)))
> insert into myschema.edges2_vertices_pgr(id,the_geom) (select id,the_geom from numberedLines join maxid using(id) where i=maxi order by id)
> NOTICE: PROCESSING:
> NOTICE: Populating myschema.Edges2_vertices_pgr, please wait...
> LINE 12: insert into myschema."Edges2_vertices_pgr"(id,the_geom) (...
> QUERY: with
> lines as ((select distinct source as id, pgr_startpoint(st_linemerge(the_geom)) as the_geom from myschema."Edges2" where (the_geom IS NULL
> or source is null
> AND (true))
> union (select distinct target as id,pgr_endpoint(st_linemerge(the_geom)) as the_geom from myschema."Edges2" where (the_geom IS NULL
> or source is null
> AND (true)))
> insert into myschema."Edges2_vertices_pgr"(id,the_geom) (select id,the_geom from numberedLines join maxid using(id) where i=maxi order by id)
> NOTICE: PROCESSING:
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> QUERY: with
> or source is null
> AND (eid<15))
> or source is null
> AND (eid<15)))
> NOTICE: PROCESSING:
> QUERY: with
> or source is null
> AND (true))
> or source is null
> AND (true)))
> NOTICE: PROCESSING:
> QUERY: with
> or source is null
> AND (eid<15))
> or source is null
> AND (eid<15)))
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> NOTICE: ERROR: source column "gid" not found in myschema.edges2
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> QUERY: with
> or source is null
> AND (eid<15))
> or source is null
> AND (eid<15)))
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'Edges2\',\'the_geom\',\'source\',\'target\',\'eid<15 and eid>5\')
> QUERY: with
> or source is null
> or source is null
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'Edges2\',\'the_geom\',\'source\',\'target\',\' the_geom && (select st_buffer(the_geom,0.0001) as buffer from "Edges2"
63,65c899,935
< OK
< FAIL
< FAIL
> LINE 14: insert into myschema."Edges2_vertices_pgr"(id,the_geom) (...
> QUERY: with
> or source is null
> AND ( the_geom && (select st_buffer(the_geom,0.0001) as buffer from "Edges2"
> where eid=6)))
> or source is null
> where eid=6))))
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'edges2\',\'the_geom\',\'source\',\'target\',\'eid<\')
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'Edges2\',\'the_geom\',\'source\',\'target\',\'eid<15 and ed>5\')
> FAIL
> NOTICE: PROCESSING:
> NOTICE: pgr_createVerticesTable(\'Edges2\',\'the_geom\',\'source\',\'target\',\' the_geom && (select st_buffer(the_geom,0.0001 as buffer from "Edges2" where eid=6)\')
'src/common/test/gettablename-any-01.test' => 'Passed',
'src/common/test/versionless-any-01.test' => 'Passed'
'src/dijkstra/test/test.conf' => [
'comment' => 'Dijkstra test for any versions.',
'src/dijkstra/test/spd-any-00.test' => 'Passed',
'src/dijkstra/test/spd-any-01.test' => 'Passed',
'src/dijkstra/test/spd-any-02.test' => 'Passed',
'src/dijkstra/test/spd-any-03.test' => 'Passed',
'src/dijkstra/test/spd-any-04.test' => 'Passed'
'src/driving_distance/test/test.conf' => [
'comment' => 'Driving Distance test for any versions.',
'src/driving_distance/test/drivingdistance-any-00.test' => 'Passed'
'src/kdijkstra/test/test.conf' => [
'src/kdijkstra/test/kdijkstra-any-01.test' => 'Passed',
'src/kdijkstra/test/kdijkstra-any-02.test' => 'Passed',
'src/kdijkstra/test/kdijkstra-any-03.test' => 'Passed'
'src/ksp/test/test.conf' => [
'comment' => 'KSP test for any versions.',
'src/ksp/test/ksp-any-01.test' => 'Passed',
'src/ksp/test/ksp-any-02.test' => 'Passed'
'src/trsp/test/test.conf' => [
'comment' => 'TRSP test for any versions.',
'src/trsp/test/trsp-any-00.test' => 'Passed',
'src/trsp/test/trsp-any-01.test' => 'Passed',
'src/trsp/test/trsp-any-02.test' => 'Passed',
'src/trsp/test/trsp-any-03.test' => 'Passed'
'src/tsp/test/test.conf' => [
'comment' => 'TSP test for any versions.',
'src/tsp/test/tsp-any-00.test' => 'Passed',
'src/tsp/test/tsp-any-01.test' => 'Passed',
'src/tsp/test/tsp-any-02.test' => 'Passed',
'src/tsp/test/tsp-any-03.test' => 'Passed',
'src/tsp/test/tsp-any-04.test' => 'Passed',
'src/tsp/test/tsp-any-05.test' => 'Passed'
'z_crash' => 0,
'z_fail' => 23,
'z_pass' => 42
Done. Your build exited with 0.
222.2 4 min 40 sec 36 minutes ago gcc POSTGRESQL_VERSION=9.1 POSTGIS_VERSION=1.5
  List of databases
Name | Owner | Encoding | Collate | Ctype | Access privileges
(5 rows)
POSTGIS="1.5.8" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.7.1, 23 September 2009" LIBXML="2.7.8" USE_STATS
(1 row)
pgr_version
(1 row)
RUNNING: test-runner.pl -pgver 9.1 -ignorenotice
CREATE TYPE
CREATE TYPE
CREATE TYPE
CREATE FUNCTION
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
COMMENT
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
test run time: 0.134347
test run time: 0.099068
test run time: 0.094982
test run time: 0.102386
test run time: 0.093742
test run time: 0.103204
test run time: 0.114919
test run time: 0.116916
test run time: 0.184272
test run time: 0.114157
test run time: 0.103159
test run time: 0.200469
test run time: 0.112147
test run time: 0.103898
test run time: 0.391323
test run time: 0.270898
test run time: 0.275993
test run time: 0.122491
test run time: 0.378337
test run time: 0.179075
test run time: 0.139414
test run time: 0.150927
test run time: 0.152931
test run time: 0.159878
test run time: 0.143246
test run time: 0.169726
test run time: 0.248014
test run time: 0.320893
test run time: 0.261617
test run time: 0.619649
test run time: 0.271431
test run time: 4.23378
test run time: 2.931249
test run time: 1.291808
test run time: 0.141352
test run time: 0.119556
test run time: 0.151362
test run time: 0.119789
test run time: 0.114299
test run time: 0.142408
test run time: 0.131554
test run time: 0.126168
test run time: 0.136794
test run time: 0.109039
test run time: 0.116185
test run time: 0.142801
test run time: 0.171446
test run time: 0.124622
test run time: 0.222553
test run time: 0.172139
test run time: 0.166157
test run time: 0.21274
test run time: 1.721792
test run time: 0.252529
test run time: 0.136772
test run time: 0.127572
test run time: 0.119652
test run time: 0.127103
test run time: 0.113359
test run time: 0.162852
test run time: 0.145208
test run time: 0.14386
test run time: 0.152747
test run time: 0.163876
test run time: 0.147628
$stats = {
< 0.5|3.5
< 0|2
< 2|0
< 4|1
< 4|2
< 4|3
< 3.5|4
< 2|4
< OK
< OK
< OK
< FAIL
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL',
< OK
> FAIL',
< 0|1|1|0
< 1|1|2|1
< 2|1|5|2
< 3|1|6|3
< 4|1|9|4
< 5|1|10|3
< 6|1|11|4
< 7|1|12|5
< 8|1|13|4
< 9|2|2|0
< 0|1|1|0
< 1|1|2|1
< 2|1|3|0
< 3|1|4|-1
< 4|1|5|2
< 5|1|6|1
< 6|1|11|2
< 7|1|10|3
< 8|1|12|1
< 9|1|13|4
< 0|4|16|1
< 1|9|9|1
< 2|6|8|1
< 3|5|10|1
< 4|10|-1|0
< 0|4|3|1
< 1|3|2|1
< 2|2|4|1
< 3|5|10|1
< 4|10|-1|0
< 0|7|6|1
< 1|8|7|1
< 2|5|8|1
< 3|6|9|1
< 4|9|15|1
< 5|12|-1|0
< 0|7|6|1
< 1|8|7|1
< 2|5|8|1
< 3|6|9|1
< 4|9|15|1
< 5|12|-1|0
< 0|4|3|0
< 1|3|5|1
< 2|6|11|1
< 3|11|12|0
< 4|10|-1|0
< 0|4|3|1
< 1|3|5|1
< 2|6|8|1
< 3|5|10|1
< 4|10|-1|0
< OK
< OK
4,21c2,24
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL',
< OK
< OK
4,20c2,23
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL',
< 0|7|6|1
< 1|8|7|1
< 2|5|8|1
< 3|6|9|1
< 4|9|15|1
< 5|12|-1|0
< 0|7|6|1
< 1|8|7|1
< 2|5|8|1
< 3|6|9|1
< 4|9|15|1
< 5|12|-1|0
< 0|3|1
< 1|5|1
< 2|6|0
< 3|9|1
< 4|11|1
< 0|5|1
< 1|6|0
< 2|9|1
< 3|11|1
< 0|10|4|4
< 1|10|12|2
< 0|4|10|12|1
< 1|4|11|13|1
< 2|4|12|15|1
< 3|4|9|16|1
< 4|4|4|-1|0
< 5|12|10|12|1
< 6|12|11|13|1
< 7|12|12|-1|0
< OK
< OK
< OK
< 1|1
< 2|1
< 3|1
< 4|1
< 5|1
< 6|1
< 7|1
< 8|1
< 9|1
< 10|1
< 11|1
< 12|1
< 13|1
< 13|2
< 14|1
< 14|2
< 15|1
< 16|1
< 17|1
< 18|1
< 18|2
< OK
< OK
< OK
< OK
< OK
< OK
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL
> FAIL',
> CONTEXT: PL/pgSQL function "pgr_pointsaspolygon" line 14 at FOR over EXECUTE statement',
< OK
> FAIL',
< 0|7|6|1
< 1|8|7|1
< 2|5|8|1
< 3|6|11|1
< 4|11|13|1
< 5|12|-1|0
< 0|7|6|1
< 1|8|7|1
< 2|5|8|1
< 3|6|11|1
< 4|11|13|1
< 5|12|-1|0
< 2|1|2|1.00
< 3|0|1|1.41
< 4|2|3|1.00
< 5|7|8|1.41
< 6|3|4|1.00
< 7|8|9|1.00
< 8|11|12|1.00
< 9|10|11|1.41
< 10|12|13|1.00
< 11|9|10|2.24
> 2|9|10|1.00
> 3|12|13|1.41
> 4|10|11|1.00
> 5|11|12|1.00
> 6|8|9|1.00
> 7|3|4|1.41
> 8|7|8|1.00
> 9|2|3|1.41
> 10|0|1|1.00
> 11|1|2|2.24
22,38c22,32
< 0|5|6|1.41
< 1|3|4|0.00
< 2|11|12|0.00
< 3|8|9|0.71
< 4|16|17|0.00
< 5|15|16|0.71
< 6|2|3|0.00
< 7|10|11|1.41
< 8|1|2|0.00
< 9|12|13|2.12
< 10|13|14|0.71
< 11|6|7|1.41
< 12|7|8|1.41
< 13|9|10|0.00
< 14|0|1|0.00
< 15|14|15|0.00
< 16|4|5|1.41
> order by a.id, b.id
> CONTEXT: PL/pgSQL function "pgr_makedistancematrix" line 17 at FOR over EXECUTE statement
> PL/pgSQL function "pgr_tsp" line 8 at RETURN QUERY',
'src/common/test/common-any-02.test' => 'Passed',
'src/common/test/common-any-04.test' => 'FAILED: 77c77,85
> NOTICE: PROCESSING:
78a87,100
> NOTICE: PROCESSING:
> NOTICE: Analyzing for gaps. Please wait...
> NOTICE: Analyzing for isolated edges. Please wait...
> NOTICE: Analyzing for ring geometries. Please wait...
> NOTICE: Analyzing for intersections. Please wait...
> NOTICE: ANALYSIS RESULTS FOR SELECTED EDGES:
> NOTICE: Isolated segments: 0
> NOTICE: Dead ends: 16
> NOTICE: Potential gaps found near dead ends: 0
> NOTICE: Intersections detected: 0
> NOTICE: Ring geometries: 0
79a102,109
> NOTICE: PROCESSING:
> NOTICE: Found 16 potential problems in directionality',
2a3,10
> NOTICE: PROCESSING:
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< OK
< OK
< OK
< FAIL
< FAIL
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
'src/common/test/createVerticesTable-any-01.test' => 'FAILED: 0a1,543
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> NOTICE: -----> VERTICES TABLE CREATED WITH 20 VERTICES
> NOTICE: FOR 23 EDGES
> NOTICE: Edges with NULL geometry,source or target: 0
> NOTICE: Edges processed: 23
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> NOTICE: -----> VERTICES TABLE CREATED WITH 13 VERTICES
> NOTICE: FOR 16 EDGES
> NOTICE: Edges processed: 16
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> NOTICE: -----> VERTICES TABLE CREATED WITH 9 VERTICES
> NOTICE: FOR 10 EDGES
> NOTICE: Edges processed: 10
> OK
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> NOTICE: FOR 24 EDGES
> NOTICE: Edges with NULL geometry,source or target: 1
> OK
> NOTICE: PROCESSING:
> NOTICE: Edges with NULL geometry,source or target: 2
> NOTICE: Edges processed: 22
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> NOTICE: Edges processed: 9
2,61c545,546
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< OK
< OK
> NOTICE: PROCESSING:
63,65c548,573
< OK
< FAIL
< FAIL
> NOTICE: -----> VERTICES TABLE CREATED WITH 5 VERTICES
> NOTICE: FOR 4 EDGES
> NOTICE: Edges processed: 3
> OK
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
'z_crash' => 0,
'z_fail' => 22,
'z_pass' => 43
222.3 5 min 44 sec 36 minutes ago gcc POSTGRESQL_VERSION=9.1 POSTGIS_VERSION=2.0
  List of databases
(5 rows)
POSTGIS="2.0.3 r11128" GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.8.0" LIBJSON="UNKNOWN" RASTER
(1 row)
pgr_version
(1 row)
CREATE EXTENSION
CREATE EXTENSION
test run time: 0.406655
test run time: 0.131019
test run time: 0.235523
test run time: 0.112231
test run time: 0.112679
test run time: 0.115716
test run time: 0.122081
test run time: 0.119326
test run time: 0.125531
test run time: 0.112815
test run time: 0.344286
test run time: 0.238133
test run time: 0.109213
test run time: 0.114839
test run time: 1.565811
test run time: 0.800207
test run time: 1.805677
test run time: 0.144978
test run time: 0.834094
test run time: 1.686612
test run time: 1.541682
test run time: 1.531228
test run time: 0.42946
test run time: 0.197932
test run time: 0.153007
test run time: 0.147959
test run time: 0.090418
test run time: 0.095063
test run time: 0.080368
test run time: 0.110352
test run time: 0.114461
test run time: 0.122817
test run time: 0.088453
test run time: 0.121253
test run time: 0.093385
test run time: 0.433915
test run time: 0.086522
test run time: 0.087129
test run time: 0.098909
test run time: 0.108685
test run time: 0.194169
test run time: 0.28176
test run time: 0.224952
test run time: 0.484178
test run time: 0.255027
test run time: 3.990297
test run time: 3.240774
test run time: 3.111101
test run time: 0.35515
test run time: 0.097277
test run time: 0.114876
test run time: 0.112541
test run time: 0.278737
test run time: 0.123009
test run time: 0.132545
test run time: 0.250029
test run time: 0.120018
test run time: 0.120729
test run time: 0.131343
test run time: 0.112443
test run time: 0.104677
test run time: 0.10272
test run time: 0.103068
test run time: 0.105578
test run time: 0.106256
$stats = {
'doc/test/alphashape-any.test' => 'Passed',
'doc/test/analyzeGraph-any.test' => 'Passed',
'doc/test/analyzeOneway-any.test' => 'Passed',
'doc/test/apspJohnson-any.test' => 'Passed',
'doc/test/apspWarshall-any.test' => 'Passed',
'doc/test/astar-any.test' => 'Passed',
'doc/test/bdDijkstra-any.test' => 'Passed',
'doc/test/bdstar-any.test' => 'Passed',
'doc/test/createTopology-any.test' => 'Passed',
'doc/test/createVertTab-any.test' => 'Passed',
'doc/test/dijkstra-any.test' => 'Passed',
'doc/test/drivingDistance-any.test' => 'Passed',
'doc/test/kdijkstra-any.test' => 'Passed',
'doc/test/nodeNetwork-any.test' => 'Passed',
'doc/test/pointsAsPolygon-any.test' => 'Passed',
'doc/test/sampledata.test' => 'Passed',
'doc/test/trsp-any.test' => 'Passed',
< 2|1|2|1.00
< 3|0|1|1.41
< 4|2|3|1.00
< 5|7|8|1.41
< 6|3|4|1.00
< 7|8|9|1.00
< 8|11|12|1.00
< 9|10|11|1.41
< 10|12|13|1.00
< 11|9|10|2.24
> 2|9|10|1.00
> 3|12|13|1.41
> 4|10|11|1.00
> 5|11|12|1.00
> 6|8|9|1.00
> 7|3|4|1.41
> 8|7|8|1.00
> 9|2|3|1.41
> 10|0|1|1.00
> 11|1|2|2.24
22,37c22,37
< 0|5|6|1.41
< 1|3|4|0.00
< 2|11|12|0.00
< 3|8|9|0.71
< 4|16|17|0.00
< 5|15|16|0.71
< 6|2|3|0.00
< 7|10|11|1.41
< 8|1|2|0.00
< 9|12|13|2.12
< 10|13|14|0.71
< 11|6|7|1.41
< 12|7|8|1.41
< 13|9|10|0.00
< 14|0|1|0.00
< 15|14|15|0.00
> 0|5|6|0.00
> 1|10|11|0.00
> 2|2|3|0.71
> 3|15|16|0.71
> 4|8|9|0.00
> 5|11|12|0.00
> 6|3|4|0.71
> 7|16|17|2.12
> 8|0|1|0.00
> 9|12|13|0.00
> 10|9|10|2.83
> 11|6|7|0.71
> 12|13|14|0.71
> 13|7|8|1.41
> 14|14|15|0.00
> 15|1|2|0.00',
'src/common/test/common-any-04.test' => 'FAILED: 77a78,85
> NOTICE: PROCESSING:
78a87,100
> NOTICE: PROCESSING:
79a102,109
> NOTICE: PROCESSING:
'src/common/test/common-any-05.test' => 'FAILED: 2a3,10
> NOTICE: PROCESSING:
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< OK
< OK
< OK
< FAIL
< FAIL
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
2,61c545,546
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< OK
< OK
> NOTICE: PROCESSING:
63,65c548,573
< OK
< FAIL
< FAIL
> NOTICE: FOR 4 EDGES
> OK
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
'z_crash' => 0,
'z_fail' => 5,
'z_pass' => 60
222.4 6 min 2 sec 35 minutes ago gcc POSTGRESQL_VERSION=9.2 POSTGIS_VERSION=2.0
  List of databases
postgres | postgres | UTF8 | en_US.UTF-8 | en_US.UTF-8 |
template0 | postgres | UTF8 | en_US.UTF-8 | en_US.UTF-8 | =c/postgres +
| | | | | postgres=CTc/postgres
template1 | postgres | UTF8 | en_US.UTF-8 | en_US.UTF-8 | =c/postgres +
template_pgrouting | postgres | UTF8 | en_US.UTF-8 | en_US.UTF-8 |
template_postgis | postgres | UTF8 | en_US.UTF-8 | en_US.UTF-8 |
(5 rows)
postgis_full_version
(1 row)
pgr_version
(2.0.0-dev,v2.0.0-rc1,105,592406b,develop,1.46.1)
(1 row)
RUNNING: test-runner.pl -pgver 9.2
CREATE EXTENSION
CREATE EXTENSION
Processing test: sampledata
test run time: 0.256609
Processing test: alphashape-any
test run time: 0.090345
Processing test: apspJohnson-any
test run time: 0.085371
Processing test: apspWarshall-any
test run time: 0.088426
Processing test: astar-any
test run time: 0.086656
Processing test: bdstar-any
test run time: 0.088873
Processing test: bdDijkstra-any
test run time: 0.089343
Processing test: dijkstra-any
test run time: 0.08798
Processing test: drivingDistance-any
test run time: 0.088475
Processing test: pointsAsPolygon-any
test run time: 0.093673
Processing test: kdijkstra-any
test run time: 0.09247
Processing test: tsp-any
test run time: 0.17423
Processing test: trsp-any
test run time: 0.184842
Processing test: utilities-any
test run time: 0.084223
Processing test: createTopology-any
test run time: 1.714947
Processing test: createVertTab-any
test run time: 1.427049
Processing test: analyzeGraph-any
test run time: 1.560488
Processing test: analyzeOneway-any
test run time: 0.125009
Processing test: nodeNetwork-any
test run time: 0.711056
Processing test: tsp-any-00
test run time: 0.142651
Processing test: tsp-any-01
test run time: 0.120772
Processing test: tsp-any-02
test run time: 0.10101
Processing test: tsp-any-03
test run time: 0.130341
Processing test: tsp-any-04
test run time: 0.118442
Processing test: tsp-any-05
test run time: 0.139625
Processing test: spas-any-00
test run time: 0.085144
Processing test: spas-any-01
test run time: 0.082171
Processing test: bd_dijkstra-any-01
test run time: 0.108382
Processing test: bd_dijkstra-any-02
test run time: 0.108646
Processing test: bd_dijkstra-any-03
test run time: 0.102266
Processing test: bd_dijkstra-any-04
test run time: 0.100238
Processing test: bd_dijkstra-any-05
test run time: 0.106415
Processing test: bd_dijkstra-any-06
test run time: 0.107288
Processing test: kdijkstra-any-01
test run time: 0.093127
Processing test: kdijkstra-any-02
test run time: 0.084796
Processing test: kdijkstra-any-03
test run time: 0.090469
Processing test: apsp_johnson-any-00
test run time: 0.092638
Processing test: trsp-any-00
test run time: 0.088218
Processing test: trsp-any-01
test run time: 0.083087
Processing test: trsp-any-02
test run time: 0.084822
Processing test: trsp-any-03
test run time: 0.083429
Processing test: ksp-any-01
test run time: 0.097984
Processing test: ksp-any-02
test run time: 0.132429
Processing test: versionless-any-01
test run time: 0.143629
Processing test: common-any-01
test run time: 1.205675
Processing test: common-any-02
test run time: 0.277182
Processing test: common-any-03
test run time: 0.239749
Processing test: common-any-04
test run time: 0.564801
Processing test: common-any-05
test run time: 0.265142
Processing test: createTopology-any-01
test run time: 3.670039
Processing test: createVerticesTable-any-01
test run time: 2.583984
Processing test: gettablename-any-01
test run time: 0.61451
Processing test: spd-any-00
test run time: 0.085611
Processing test: spd-any-01
test run time: 0.086396
Processing test: spd-any-02
test run time: 0.083485
Processing test: spd-any-03
test run time: 0.084802
Processing test: spd-any-04
test run time: 0.083924
Processing test: apsp_warshall-any-00
Processing test: drivingdistance-any-00
test run time: 0.094623
Processing test: bd_astar-any-01
test run time: 0.106953
Processing test: bd_astar-any-02
test run time: 0.10203
Processing test: bd_astar-any-03
test run time: 0.104062
Processing test: bd_astar-any-04
test run time: 0.105127
Processing test: bd_astar-any-05
test run time: 0.107954
Processing test: bd_astar-any-06
test run time: 0.10501
$stats = {
'doc/test/test.conf' => [
'comment' => 'documentation SQL tests for any versions.',
< 2|1|2|1.00
< 3|0|1|1.41
< 4|2|3|1.00
< 5|7|8|1.41
< 6|3|4|1.00
< 7|8|9|1.00
< 8|11|12|1.00
< 9|10|11|1.41
< 10|12|13|1.00
< 11|9|10|2.24
> 2|9|10|1.00
> 3|12|13|1.41
> 4|10|11|1.00
> 5|11|12|1.00
> 6|8|9|1.00
> 7|3|4|1.41
> 8|7|8|1.00
> 9|2|3|1.41
> 10|0|1|1.00
> 11|1|2|2.24
22,37c22,37
< 0|5|6|1.41
< 1|3|4|0.00
< 2|11|12|0.00
< 3|8|9|0.71
< 4|16|17|0.00
< 5|15|16|0.71
< 6|2|3|0.00
< 7|10|11|1.41
< 8|1|2|0.00
< 9|12|13|2.12
< 10|13|14|0.71
< 11|6|7|1.41
< 12|7|8|1.41
< 13|9|10|0.00
< 14|0|1|0.00
< 15|14|15|0.00
> 0|5|6|0.00
> 1|10|11|0.00
> 2|2|3|0.71
> 3|15|16|0.71
> 4|8|9|0.00
> 5|11|12|0.00
> 6|3|4|0.71
> 7|16|17|2.12
> 8|0|1|0.00
> 9|12|13|0.00
> 10|9|10|2.83
> 11|6|7|0.71
> 12|13|14|0.71
> 13|7|8|1.41
> 14|14|15|0.00
> 15|1|2|0.00',
'src/common/test/common-any-04.test' => 'Passed',
'src/common/test/common-any-05.test' => 'Passed',
'src/common/test/createTopology-any-01.test' => 'Passed',
'src/common/test/createVerticesTable-any-01.test' => 'Passed',
'z_crash' => 0,
'z_fail' => 1,
'z_pass' => 64
222.5 4 min 31 sec 38 minutes ago gcc POSTGRESQL_VERSION=9.1 POSTGIS_VERSION=2.1
  List of databases
(5 rows)
POSTGIS="2.2.0dev" GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.8.0" LIBJSON="UNKNOWN" (core procs from "2.2.0dev" need upgrade) RASTER (raster procs from "2.2.0dev" need upgrade)
(1 row)
pgr_version
(1 row)
CREATE EXTENSION
CREATE EXTENSION
test run time: 0.187194
test run time: 0.096697
test run time: 0.086869
test run time: 0.089483
test run time: 0.099292
test run time: 0.09804
test run time: 0.106119
test run time: 0.103197
test run time: 0.188484
test run time: 0.109805
test run time: 0.20431
test run time: 0.093234
test run time: 0.14256
test run time: 1.309949
test run time: 1.050513
test run time: 1.548622
test run time: 0.185121
test run time: 0.636586
test run time: 0.181303
test run time: 0.099037
test run time: 0.093364
test run time: 0.090385
test run time: 0.104892
test run time: 0.086962
test run time: 0.102057
test run time: 0.103289
test run time: 0.220916
test run time: 0.127581
test run time: 0.113334
test run time: 0.200814
test run time: 0.119972
test run time: 0.202123
test run time: 0.098705
test run time: 0.125081
test run time: 0.109048
test run time: 0.091956
test run time: 0.116732
test run time: 0.117799
test run time: 0.11157
test run time: 0.143369
test run time: 0.164944
test run time: 0.141272
test run time: 0.153959
test run time: 0.101634
test run time: 0.158445
test run time: 0.113964
test run time: 0.135176
test run time: 0.129696
test run time: 0.133469
test run time: 0.124844
test run time: 0.133295
test run time: 0.265957
test run time: 0.130066
test run time: 0.261235
test run time: 0.279745
test run time: 0.254629
test run time: 0.596947
test run time: 0.376898
test run time: 3.907096
test run time: 2.469855
test run time: 0.712772
test run time: 0.087798
test run time: 0.09234
test run time: 0.092078
$stats = {
'doc/test/tsp-any.test' => 'FAILED: 3,12c3,12
< 2|1|2|1.00
< 3|0|1|1.41
< 4|2|3|1.00
< 5|7|8|1.41
< 6|3|4|1.00
< 7|8|9|1.00
< 8|11|12|1.00
< 9|10|11|1.41
< 10|12|13|1.00
< 11|9|10|2.24
> 2|9|10|1.00
> 3|12|13|1.41
> 4|10|11|1.00
> 5|11|12|1.00
> 6|8|9|1.00
> 7|3|4|1.41
> 8|7|8|1.00
> 9|2|3|1.41
> 10|0|1|1.00
> 11|1|2|2.24
22,37c22,37
< 0|5|6|1.41
< 1|3|4|0.00
< 2|11|12|0.00
< 3|8|9|0.71
< 4|16|17|0.00
< 5|15|16|0.71
< 6|2|3|0.00
< 7|10|11|1.41
< 8|1|2|0.00
< 9|12|13|2.12
< 10|13|14|0.71
< 11|6|7|1.41
< 12|7|8|1.41
< 13|9|10|0.00
< 14|0|1|0.00
< 15|14|15|0.00
> 0|5|6|0.00
> 1|10|11|0.00
> 2|2|3|0.71
> 3|15|16|0.71
> 4|8|9|0.00
> 5|11|12|0.00
> 6|3|4|0.71
> 7|16|17|2.12
> 8|0|1|0.00
> 9|12|13|0.00
> 10|9|10|2.83
> 11|6|7|0.71
> 12|13|14|0.71
> 13|7|8|1.41
> 14|14|15|0.00
> 15|1|2|0.00',
'doc/test/utilities-any.test' => 'Passed'
'src/apsp_johnson/test/test.conf' => [
'comment' => 'APSP Johnson test for any versions.',
'src/apsp_johnson/test/apsp_johnson-any-00.test' => 'Passed'
'src/apsp_warshall/test/test.conf' => [
'comment' => 'APSP Warshall test for any versions.',
'src/apsp_warshall/test/apsp_warshall-any-00.test' => 'Passed'
'src/astar/test/test.conf' => [
'comment' => 'astar test for any versions.',
'src/astar/test/spas-any-00.test' => 'Passed',
'src/astar/test/spas-any-01.test' => 'Passed'
'src/bd_astar/test/test.conf' => [
'comment' => 'Bi-directional AStar test for any versions.',
'src/bd_astar/test/bd_astar-any-01.test' => 'Passed',
'src/bd_astar/test/bd_astar-any-02.test' => 'Passed',
'src/bd_astar/test/bd_astar-any-03.test' => 'Passed',
'src/bd_astar/test/bd_astar-any-04.test' => 'Passed',
'src/bd_astar/test/bd_astar-any-05.test' => 'Passed',
'src/bd_astar/test/bd_astar-any-06.test' => 'Passed'
'src/bd_dijkstra/test/test.conf' => [
'comment' => 'Bi-directional Dijkstra test for any versions.',
'src/bd_dijkstra/test/bd_dijkstra-any-01.test' => 'Passed',
'src/bd_dijkstra/test/bd_dijkstra-any-02.test' => 'Passed',
'src/bd_dijkstra/test/bd_dijkstra-any-03.test' => 'Passed',
'src/bd_dijkstra/test/bd_dijkstra-any-04.test' => 'Passed',
'src/bd_dijkstra/test/bd_dijkstra-any-05.test' => 'Passed',
'src/bd_dijkstra/test/bd_dijkstra-any-06.test' => 'Passed'
'src/common/test/test.conf' => [
'comment' => 'pgr_createTopology, pgr_analyzegraph, and pgr_analyzeOneway tests for any versions.',
'src/common/test/common-any-01.test' => 'Passed',
> NOTICE: PROCESSING:
78a87,100
> NOTICE: PROCESSING:
79a102,109
> NOTICE: PROCESSING:
> NOTICE: PROCESSING:
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< OK
< OK
< OK
< FAIL
< FAIL
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> OK
> NOTICE: PROCESSING:
2,61c545,546
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< FAIL
< OK
< OK
> NOTICE: PROCESSING:
63,65c548,573
< OK
< FAIL
< FAIL
> NOTICE: FOR 4 EDGES
> OK
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
> FAIL
> NOTICE: PROCESSING:
'z_crash' => 0,
'z_fail' => 5,
'z_pass' => 60
222.6 7 min 2 sec 29 minutes ago gcc POSTGRESQL_VERSION=9.2 POSTGIS_VERSION=2.1
  List of databases
(5 rows)
(1 row)
pgr_version
(1 row)
CREATE EXTENSION
CREATE EXTENSION
test run time: 0.745738
test run time: 0.118977
test run time: 0.094217
test run time: 0.103692
test run time: 0.106586
test run time: 0.268794
test run time: 0.086116
test run time: 0.096277
test run time: 0.094278
test run time: 0.151274
test run time: 0.154543
test run time: 0.199875
test run time: 0.447349
test run time: 5.004514
test run time: 1.642744
test run time: 2.100954
test run time: 0.129931
test run time: 1.176159
test run time: 0.105039
test run time: 0.098891
test run time: 0.094388
test run time: 0.089199
test run time: 0.094024
test run time: 0.095451
test run time: 0.089763
test run time: 0.0970800000000001
test run time: 0.091658
test run time: 0.091311
test run time: 0.088067
test run time: 0.090018
test run time: 0.14731
test run time: 0.127477
test run time: 0.10621
test run time: 0.138924
test run time: 0.210688
test run time: 0.237384
test run time: 0.094629
test run time: 0.12093
test run time: 0.115626
test run time: 0.109457
test run time: 0.109531
test run time: 0.113814
test run time: 0.086546
test run time: 0.0872
test run time: 0.08876
test run time: 0.085783
test run time: 0.117931
test run time: 0.12521
test run time: 0.148883
test run time: 0.156684
test run time: 0.142579
test run time: 0.10999
test run time: 0.166854
test run time: 0.115724
test run time: 0.145449
test run time: 0.630911
test run time: 0.314178
test run time: 0.432861
test run time: 1.209712
test run time: 0.572715
test run time: 5.91105
test run time: 3.387912
test run time: 0.685979
$stats = {
< 2|1|2|1.00
< 3|0|1|1.41
< 4|2|3|1.00
< 5|7|8|1.41
< 6|3|4|1.00
< 7|8|9|1.00
< 8|11|12|1.00
< 9|10|11|1.41
< 10|12|13|1.00
< 11|9|10|2.24
> 2|9|10|1.00
> 3|12|13|1.41
> 4|10|11|1.00
> 5|11|12|1.00
> 6|8|9|1.00
> 7|3|4|1.41
> 8|7|8|1.00
> 9|2|3|1.41
> 10|0|1|1.00
> 11|1|2|2.24
22,37c22,37
< 0|5|6|1.41
< 1|3|4|0.00
< 2|11|12|0.00
< 3|8|9|0.71
< 4|16|17|0.00
< 5|15|16|0.71
< 6|2|3|0.00
< 7|10|11|1.41
< 8|1|2|0.00
< 9|12|13|2.12
< 10|13|14|0.71
< 11|6|7|1.41
< 12|7|8|1.41
< 13|9|10|0.00
< 14|0|1|0.00
< 15|14|15|0.00
> 0|5|6|0.00
> 1|10|11|0.00
> 2|2|3|0.71
> 3|15|16|0.71
> 4|8|9|0.00
> 5|11|12|0.00
> 6|3|4|0.71
> 7|16|17|2.12
> 8|0|1|0.00
> 9|12|13|0.00
> 10|9|10|2.83
> 11|6|7|0.71
> 12|13|14|0.71
> 13|7|8|1.41
> 14|14|15|0.00
> 15|1|2|0.00',
'src/common/test/common-any-03.test' => 'Passed',
'z_crash' => 0,
'z_fail' => 1,
'z_pass' => 64
