I cannot seem to work this out myself, so hopefully no one minds if I ask here ![]()
I have a layer that retrieves latitude and longitude recorded over the last 3 days and converts them into points. Can a SLD styling fill in the points using a colour between red and green, depending on how long ago the point’s timestamp was?
Adding an ‘age’ column into the SQL view should be no problem, but I don’t quite know how to work that into the styling.
A colourmap will be a suitable alternative if true interpolation is impossible, assuming if even that is possible with points.
