Sorry if this gets twice, but I have not received any posting from the user
list since Friday (even this posting which I sent earlier today).
GRASS users--
I have a digitized representation of a set of polygons, such as a soils map.
Unfortunately, the map is divided into a serial of data sets where each data
set contains complete polygons for all areas of that same value. That is,
data set number 1 contains complete polygons for all areas designated as soil
type 1; data set number 2 contains complete polygons for all areas designated
as soil type 2; and so on. Also, none of the polygons have attribute or label
points associated with them (but I know what their label should be based upon
the data set the polygon is in).
I can import the separate files into GRASS and make separate dig files. My
first question:
1. Is there any way to bulk label polygons within GRASS (much like bulk
labeling of lines within v.digit)? If there is no way to automatically label
a polygon, is there a way to generate a centroid within a GRASS polygon?
If I can efficiently label the polygons by data set, I then intend to v.patch
the various dig files together. My next question then:
2. Can I eliminate the overlap between the edges of two adjoining polygons?
That is, can I convert the complete polygons which result in the storage of
duplicate coordinates between adjoining polygons into a vector representation
where adjoining polygons both utilize the same segment/vector to construct each
polygon? I tried the GRASS4.0 version of v.spag with threshold=0 and while it
works for part of the polygon, it seems to get 'hung in a loop' in other parts
of the data set.
Any thoughts on either of these two problems would be greatly appreciated.
Mark Gregory mg@soil.agr.okstate.edu
Oklahoma State University (405) 744-6417
P.S. Please send any replies directly to me at mg@soil.agr.okstate.edu as
our normal mailer is evidently messed up. Thanks, again.
