Lets say you have two areas separated by a single line:
____________________
| 1 | 2 |
--------------------I brought these areas in to Grass via v.in.dxf, I now want to convert tis
into two labled areas without having to digitize the polygons in v.digit.
If this can't be done in Grass directly, does anyone know if Arc/Info can
do it?
ARC/INFO certainly can do it. It has a DXFARC import, and then you must
BUILD cover POLY to get a clean polygon topology.
J. Fuerst
Internet: fuerst@donau.boku.ac.at
