PostGRASS is alive!
Hi, all
I have compiled the postgrass on linux RH5.1.
But it have Error Message: PG_HOST not set when I run g.select.pg or
g.table.pg ...
PG_HOST xxx.xxx.xxx.xxx or setenv PG_HOST pg_path both don't work.
How I should to set PG_HOST ??
BTW, I have change linux from Slackware to RH.
I used gmake4.2 to compile sources very well on Slackware, but
it seem be many errors after I install RH.
for examples:
OBJ.linux/label.o(.text+0x10b):the `gets' function is dangerous and
should not be used.
What's wrong?
Thanks for your help :slight_smile:
Der-Johng Sun djsun@gate.sinica.edu.tw
Init. Botany of Academia Sinica, Taiwan
On 20-Nov-98 Der-Johng Sun wrote:
Hi, all
g.table.pg ...
YES! you found a bug
until I post a new version on the weekend
use
g.gisenv PG_HOST={your Postgres host}
if Postgres is running local, use localhost
ie. g.gisenv PG_HOST=localhost
E-Mail: Carl Anderson <candrsn@mindspring.com>
Date: Sat, 20-Nov-98 12:00:00 +0000 (GMT)
Time: 19:55:22
This message was sent by XFMail
