postscrip printing (ps.map)? (3)
->From: buckr@qdpii.ind.dpi.qld.gov.au (Rosalie BUCK)
->Subject: ps.map & lat/long
->ps.map will print vector maps based on lat/long only if the default region
->will fit into the one panel. Selecting a region will cause ps.map to fail.
->Raster and grids accept the small region. This effect does not occur with
->UTM data.
Subj: postscrip printing (ps.map)? (3)
Dear Rosalie
I don't know if you were responding to my request, but it was a good starting
place to resolve the problem that I have been having displaying Vector maps
over Raster images in ps.map.
YES, we were working with lat lon data. I switched the mapset over to UTM,
still with raster & vector mismatch.
Could you please expand on what you mean by "default region will fit into the
one panel." Does this mean that there is a limit on the
size of a X and Y values within a region is which ps.map can work.
thankyou to all
bill...
->->We are having problems with ps.map. It appears the raster and
->->vector files overlaid on top of the raster are at different scales
->->or at different offsets than the raster file. Is there a new and
->->improved version of this code out there that corrected for this
->->(ours was downloaded on July 7)?
->->Regards,
->->Bruce Wylie
->This the second time we posted this question to the list,
->please help if you can.
->using ps.map Update Package 2 installed
-> Using d.rast and d.vect.
-> When using a raster file and then over laying a vector file,
-> we get an image with a vector tightly wrap around the raster image,
-> like in example #1.
-> Using ps.map
-> we get a nice raster image with a vector that fits nicely along
-> the bottom on the image but fails to stretch over the entire image,
-> like in example #2.
-> example #1 example #2
-> /-----\ xXXXXXx
-> /xXXXXXx\ /-----\
-> |XXXXXXX| |XXXXXXX|
-> \XXXXX/ \XXXXX/
-> What are we doing wrong? We use p.map extensively, never had a problem.
->example of our ps.map script follows
->using the command> ps.map input=bill.scr output=bill.ps
->scale 1:250000
->maploc 1.25 0.0
->grayrast x5
->vector maj.250.hy
-> color black
-> width 3
-> end
->vector sat.thick.study.irr
-> color black
-> width 1
-> end
William J. Dailey, GPSR Systems Analyst
USDA-ARS-NPA
Great Plains Systems Res. TEL: 303-490-8324
P.O. Box E FAX: 303-490-8310
303 South Howes Rm. 227 FTS2000: A03RLGPSR
Fort Collins, CO 80522 INTERNET: dailey@gpsrv1.gpsr.colostate.edu
