Sort of related question - I've managed to compile 'ghostscript' so I can
look at the output from 'ps.map' - I've tried to compile 'ghostview', but
it fails because it can't find the 'Xaw' directory, which contains some
'.h' files, e.g. Cardinal.h'It seems that these files are something to do with 'Athena' ?? - any idea
what this is ? - is it like Motif ?More importantly, if it is PD, where can I get hold of the files
necessary to compile ghostview on a Sun IPX ?Thanks for any help,
the Xaw library contains some widgets required for the compilation.
You can retrieve them from many sites. I work on HP, and I ftp-ed them
from a dedicated server, but I think that you may find them around.
You can try through the 'archie' service:
1- telnet on one of the following (user: archie, no password):
archie.au 139.130.4.6 Australia
archie.uni-linz.ac.at* 140.78.3.8 Austria
archie.univie.ac.at* 131.130.1.23 Austria
archie.uqam.ca* 132.208.250.10 Canada
archie.funet.fi 128.214.6.100 Finland
archie.cs.huji.ac.il 132.65.6.15 Israel
archie.wide.ad.jp 133.4.3.6 Japan
archie.sogang.ac.kr* 163.239.1.11 Korea
archie.hana.nm.kr* 128.134.1.1 Korea
archie.luth.se* 130.240.18.4 Sweden
archie.switch.ch* 130.59.1.40 Switzerland
archie.ncu.edu.tw 140.115.19.24 Taiwan
archie.doc.ic.ac.uk 146.169.11.3 United Kingdom
archie.unl.edu 129.93.1.14 USA (NE)
archie.rutgers.edu* 128.6.18.15 USA (NJ)
archie.ans.net 147.225.1.2 USA (NY)
archie.sura.net 128.167.254.179 USA (MD)
archie.luth.se
archie.unipi.it
2- type the command 'find [string]', e.g. 'find Xaw'
3- " " " 'mail [user@....]'
You will receive a list of sites on which Xaw is available.
Good work!
Andrea Giacomelli
andreag@idra1.iar.polimi.it
DIIAR Politecnico di Milano, Italia
