Postscript from GRASS
Steve Culshaw writes:
(i) I seem to be getting conflicting information concerning the ability
of GRASS to produce A3 Postscript - can anyone confirm that they have
produced full A3 sized maps from GRASS ?
Yes, I did and it prints on Calcomp Colormaster as well as on HP Paintjet XL
using Ghostscript 2.6.1. (Full A3 means, maybe 2 cm boundary around)
(ii) I have finally found the switch in ghostscript which sets the size
of paper (surprise, surprise -sPAPERSIZE=a3 !). Now when I view my test
A3 output, the X11 image suggests that the output is sized for an A3
piece of paper - tried an A4 output and it only filled part of the page.
This suggests that the answer to (i) above is 'yes it can'
You can use GhostView (a user friendly front end to gs to see the whole page
(zoom and pan)
Good luck,
Josef Fuerst
Dipl.Ing. Dr. Josef Fuerst
Universitaet fuer Bodenkultur
Institut fuer Wasserwirtschaft, Hydrologie und konstruktiven Wasserbau
Nussdorfer Laende 11
A-1190 Wien
AUSTRIA
Tel: +43 1 3692924 360
Fax: +43 1 3692924 350
E-mail: fuerst@donau.boku.ac.at
