At 03:46 PM 3/18/96 -0500, you wrote:
I am using grass4.1.5 on linux (slack 3.0, k1.2.13).
i am trying to generate some post script plots, but
get a segmentation fault when I try to run ps.map. I
have the ps drivers configured and selected correctly. I am
also getting a floating point excpetion error on a machine running
grass4.1.3 (slack 2.3, k1.2.8). It has no coprocessor,
but has floating point emulation enabled in the kernel...Did you get the segmentation fault error every time? Has anyone had the same
error with the Linux GRASS 4.15 binaries that available on moon?Kang,
I have had similar problems with Linux (slak 3.0, kl. 1.2.13) and GRASS
(ver. 4.15 for Linux). I installed the "new" ps.map from JS last week which
seems to work well with raster files, but only small vector files. It
responds with an "out of memory" message. I have 16 megs of ram and a 20
meg swap file. Any dig file over 13K causes the memory problem.
-Scott Grover
scottg@horne.com
