PPM painter
Now, the question is where do I find the map (file?) created with the ppm painter, so that I can convert it to a tiff file?
Doug Bradley
Southwest GIS Center
Albuquerque
Painting a map with p.map and the ppm painter results in a file called
paint.ppm in the current (mostly your $HOME) directory. I think. Painting
two maps will therefore result in an overwrite unless you rename or otherwise
protect it.
----\_\_\_--\_----\_------\_-------------------- P. Martijn van Leusen --------
     \_ \_ \_\_\_\_ \_ Dept of Pre- and Protohistoric Archaeology
      \_\_\_ \_ \_ \_ \_ University of Amsterdam, The Netherlands
       \_ \_ \_ \_\_ \_ martijn@scanner.frw.uva.nl
--------\_------\_----\_--\_--\_\_\_\_-----------------------------------------
