Precipitation Estimation
At 11.53 22/11/98 +0100, you wrote:
Hello to all.
I have the following problem (or question:)
Does anybody know of any existing tool or module that calculates point based
precipitation into the surface with respect to the orography?
I used r.surf.idw, but this does only estimate rainfall for a given surface,
but I need to take orography as well into consideration. How about
r.mapcalc? Did anyone allready made some experience with this sort of
estimation technique?
Bernhard Sturm
Bernhard Sturm
Centre for Development and Environment
Department of Geography
University of Berne
Hallerstrasse 12
3012 BERN - SWITZERLAND
http://www.datacomm.ch/sturm
If you have a previous empirical model P=f(Z) obtained from your data.
Where Z is an orographic variable (mainly altitude) and P is precipitation
You can easily program it with r.mapcalc. Unfortunatelly you need an
external program to develop the statistical analysis. There is a module in
GRASS, I don't remember the name, wich allows you to extract values from
raster layers corresponding with points in a point file.
Good luck.
      = Francisco Alonso Sarría =
      = Area de Geografía Física =
      = Universidad de Murcia =
      = Campus de La Merced =
      = E-30001 MURCIA =
      = Tlfno (968) 364357 =
      = alonsarp@fcu.um.es =
