Print maps using SPARCprinter
Hi, everyone.
First of all I'd like to thank you for the advice on creating new location and map set, and on data transfer. All those problems are solved.
Now, I am trying to print grey scale maps on a SPARCprinter which is directly
connected to my workstation running Solaris 2.2. I tred ps.map to do this,
after answering a series questions and then I got the following.
set the printer and hit RETURN -->SPARCprinter
Segmentation fault (core dumped)
Would someone tell me what I am sopposed to do here and before hand ?
Or is possible to print a GRASS map on a SPARCprinter (this name is all I know
about the printer).
Thank you.
Ye Qi
Scripps Institution of Oceanography
University of California, San Diego
La Jolla, CA 92093-0220
(619)-534-4232
qi@cdrgsun.ucsd.edu
As far as I remember there used to be a bug in the interactive version of
ps.map. I don't if it has been fixed. It is possible to run it with
command line arguments however. Here is a small script that I have used
to output simple raster maps. It shows the principle.
Happy Xmas to everyone !
Lars
#!/bin/sh
# ps.map.sh
# Script that run ps.map
# Author: Lars Schylberg ( larss@fmi.kth.se )
# Department of Photogrammetry
# Royal Inst. of Technolgy
# Stockholm, Sweden
# Date: 930216
# History of changes:
# Check if GRASS is running
test "$GISRC" || echo "GRASS is not running" || exit 2
# Evaluate arguments
if [ $# != 2 ]
then
    echo
    echo Usage: `basename $0`
    echo ' rast=mapname '
    echo ' scale=mapscale '
    echo
    exit 1
fi
# parse input arguments
for i do
  case $i in
    rast*)
      RAST=`echo $i | sed s/rast=//` ;;
    ra*)
      RAST=`echo $i | sed s/ra=//` ;;
    r*)
      RAST=`echo $i | sed s/r=//` ;;
    scale=*)
      SCALE=`echo $i | sed s/scale=//` ;;
    sc=*)
      SCALE=`echo $i | sed s/sc=//` ;;
    s=*)
      SCALE=`echo $i | sed s/s=//` ;;
      echo ""
      echo "Unrecognized option: $i"
      echo 'Options: rast=mapname '
                        echo
      exit 1
  esac
done
# Check the input arguments
eval `g.findfile element=cell file=$RAST`
if [ ! "$file" ] ; then
   echo "$RAST - clump cell file not found"
   exit 2
fi
if [ $SCALE -lt 100 -o $SCALE -gt 1000000 ]
then
   echo "This scale factor seems strange: 1:$SCALE "
   exit 2
fi
eval `g.findfile element=cell_misc file=$RAST`
echo "Map: $RAST" > comments.file
  echo "" >> comments.file
  cat $file/RULE.* >> comments.file
fi
echo "scale 1:$SCALE" > ps.map.input
echo "maploc 1.25 1.25" >> ps.map.input
echo "greyrast $RAST" >> ps.map.input
echo "colortable y" >> ps.map.input
echo "where 1.25 0" >> ps.map.input
echo "font Helvetica Bold" >> ps.map.input
echo "fontsize 10" >> ps.map.input
echo "end" >> ps.map.input
echo "comments comments.file" >> ps.map.input
echo "where 4.5 1.5" >> ps.map.input
echo "font Helvetica" >> ps.map.input
echo "color black" >> ps.map.input
echo "end " >> ps.map.input
ps.map input=ps.map.input output=$RAST.ps
rm -f ps.map.input comments.file
prf -trans $RAST.ps
rm -f $RAST.ps
