Hi' GRASS User's:
I'm have one map in format dxf, it have point that represent pit.
use v.in.dxf and v.in.support for to transform the format a GRASS4.1.
of see the vector map in the monitor appear line not points. why?
Thanks in advancing
Zorka
e-mail:viewps@llareta.dagh.uta.cl
Dear GRASS users,
I am new to this newsgroup and I am just in the process
of planning and studying how to download and install GRASS in my
LINUX system. I already found a site were I can download the LINUX
binaries of GRASS. I have been following this news group for already
5 months and my impression is that GRASS has still many problems
and bugs that needs to be fixed and if you are not an expert in
programming, you will have a lot of frustrating moments. Before I plunge
into this wonderful world of frustrations, I would like to know if my
main objective will be met by using GRASS. I recently acquired 30sec X
30sec elevation and bathymetric data which I plan to use in my
reasearch. This data is freely distributed by EDC-DAAC of the USGS. The
format according to the documentation is readable by ARCINFO. Since I
can't afford to use this expensive software, I would like to know if
there is anyone from this group who had experience in reading this type
of data using GRASS. Thank you in advance to anybody who will answer my
inquiry.
BART BAUTISTA
Dept. of Earth and Planetery Sciences
Kyoto University
Sakyoku, Kyoto 606
JAPAN
Bart C. Bautista wrote:
Dear GRASS users,
inquiry.
BART BAUTISTA
Kyoto University
Sakyoku, Kyoto 606
JAPAN
Regarding your question about improting ARC-Info data into GRASS, you
can
use the GRASS v.in.arc function and import the file into the GRASS
database.
My experience of working with GRASS for the last few years has been
quite
rewarding and thanks to this mailing list I could get over several of
the
initial problems. I think GRASS should be worth your while.
Bye
ベンカテッシュ ラガワン Venkatesh Raghavan
大阪市立大学学術情報総合センター Media Center, Osaka City Univ.
3ー3ー138杉本住吉区大阪 558 3-3-138 Sugimoto Sumiyoshi-ku, Osaka
558
Tel:06-605-3381
mailto:raghavan@media.osaka-cu.ac.jp
