Received: from SWTEXAS.BITNET by ricevm1.rice.edu (IBM VM SMTP V2R2)
with BSMTP id 3943; Mon, 01 Mar 93 08:49:31 CST
Date: Mon, 1 Mar 93 08:49 CST
Subject: Problem compiling GRASS4.1b
Sender: lists-owner@max.cecer.army.mil
Reply-To: grassu-list@max.cecer.army.mil
X-Original-To: grassu-list@max.cecer.army.mil, NW01Hi GRASSusers
I tried to install GRASS4.1beta over this weekend without success.
Here is the tail of the GISGEN.out/users/g41/src/libes/proj
make -f OBJ.aux/make.rulesrm -f OBJ.aux/PJ_aea.o
cc -O -I/users/g41/src/include -DUSE_TERMIO -c PJ_aea.c
"PJ_aea.c", line 50: HUGE_VAL undefined
"PJ_aea.c", line 54: HUGE_VAL undefined
"PJ_aea.c", line 71: HUGE_VAL undefined
Make: *** Error: Update of `OBJ.aux/PJ_aea.o' terminated with exit code 1
Make: [line 152 in /users/g41/src/libes/proj/OBJ.aux/make.rules]GISGEN failure at STEP: src/libes/proj
Could somebody tell me where the header file that define this HUGE_VAL. I
didn't have this problem in installing 4.0 on a Mac running A/UX.Nisai Wanakule
HUGE_VAL is an ANSI standard macro defined in math.h (sect. 4.5, line 7,
page 112, X3.159-1989). Its usage is usually as a flag to indicate
failure to compute some type double value. I would personally yell at
the A/UX people about this but in the mean time you can patch with a
macro in projects.h with something like:
#ifndef HUGE_VAL
#define HUGE_VAL 1e100
#endif
or some other suitably large value. HUGE_VAL is used in several other
spots in Rel.4 proj. Using GNU's gcc with their headers should also work.
Also check that there may be other compiler flags which will force
ANSI compliance---a lot of machines get confusing in this area.
G.I.Evenden, proj author.
