problem:DXF, May '97
At 12:18 PM 5/5/95 -0400, you wrote:
Hi' GRASS User's:
I'm have one map in format dxf, it have point that represent pit.
use v.in.dxf and v.in.support for to transform the format to GRASS4.1.
of see the vector map created in the monitor appear line not points. why?
Excuse me my english that isn't very good. Thanks in advancing for you help
Zorka
e-mail:viewps@llareta.dagh.uta.cl
Probably that your point was represented by a label in your cad file, so
Grass did create a line from the string.
Look in the dig_att directory, you should find the centroid for the lines.
Create a point with those coordinates (the point format description should
not be hard to find in the grass documentation).
Hope it helps...
Leslie Apollon, M.Sc Géographie
Conseiller SIG - Support Technique
LAS Inc. tel. : (514) 858-1104
1570, rue Chabanel Ouest fax : (514) 389-9373
Montréal, Québec, Canada e-mail: la@las.com
H4N 1H4
Grassland home-page : http://www.las.com/grassland
