At 09:53 AM 4/11/96 -0100, you wrote:
Hi Users,
I have exported a vector file in DLG format from ARCINFO. I'd like to import
it in GRASS using v.in.dlg but I don't know in which directory I must copy
the file!!!
I have tried to copy it in all the existing directories but v.in.dlg doesn't
work.
Someone knows the right way???thank you very much
saccon@pbox.joanneum.ac.at
GRASS will look for dlg input files in the dlg directory located under your
current mapset. You should have a directory structure similar to this:
/home/.../GISDBASE/location/mapset/[dlg,dig,dig_att,cell,etc.]. If you use
v.out.dlg on a sample file, GRASS will create the dlg subdirectory for you.
scott
scottg@horne.com
