Hi!
I have some comercial shape files that I can't import with v.in.arc. ( I use Grass 5.0b)
g.region responses with an error message "north must be north of south.." or something like that.
Could it be there ist something wrong with the projection? How can I change the projection?
The files work perfectly with ArcView 3.0.
Anybody got a solution for this problem?
Thanx, Werner Masik
e9325495@stud3.tuwien.ac.at wrote:
Hi!
Thanx, Werner Masik
Werner,
As I understand it v.in.arc reads arc/info generate files. If you want to
read shapefiles you might try building my v.in.shape program.
http://gdal.velocet.ca/projects/grass
Good luck,
I set the clouds in motion - turned up | Frank Warmerdam, warmerda@home.com
light and sound - activate the windows | http://members.home.com/warmerda
and watch the world go round - Rush | Geospatial Programmer for Rent
