Problem on Converting ARC/INFO data
Ryan,
Make sure the input ARC files are in a directory entitled "arc"
located directly underneath your PERMANENT (or other mapset)
directory. V.in.arc looks to this directoty, so if you are
trying to import the file p4211090.lin, and it isn't in the arc
directory, then GRASS will complain.
If you have further troubles, feel free to contact me regarding the
import of ARC files into GRASS
Good luck,
Scott
Scott Miller e-mail: miller@tucson.ars.ag.gov
USDA - ARS SWRC phone: (602) 670-6481 ext. 342
2000 E. Allen Rd. fax: (602) 670-5550
Tucson, AZ 85729
