I have just downloaded the latest GRASS release for Solaris2.x machines.
But whenever I run the 'd.mon x0' It complains: 'Problem selecting [x0]
will try once more.' .....The monitor window appears fine and shows up as
running if I run d.mon and then select the choose option ....and then
list -f.......but I can't select it, it doesn't tell me why, it just returns
without selecting it (whenever I try a graphic operation it complains that
no output device is selected).
I'm using the monitorcap file as it came with the distribution (though I
did try the XDRIVER.fifo and XDRIVER.n drivers but couldn't get them to
work either....they always complained about not being able to set up a pipe
for the output display).
Any advice would be greatly appreciated.
Herb Hasler.
Herb Hasler -- herb@iiasa.ac.at
International Institute for Applied Systems Analysis (IIASA)
A-2361 Laxenburg, Austria, +43 2236 807 ext 548
