I am having a problem with the vask library when I use structures
and arrays of structures containing characters. The following short
program illustrates this:
#include<gis.h>
struct char_record
char a;
char b;
struct char_record char_array[2];
main(argc,argv)
int argc;
char* argv;
G_gisinit(argv[0]);
char_array[0].a='a';
char_array[0].b='b';
char_array[1].a='c';
char_array[1].b='d';
V_clear();
V_ques(&char_array[0].a,'s',3,4,1);
V_ques(&char_array[0].b,'s',3,10,1);
V_ques(&char_array[1].a,'s',4,4,1);
V_ques(&char_array[1].b,'s',4,10,1);
V_call();
this should produce a screen looking something like this:
a b
c d
when I use <enter> to move through the fields I get this:
abcd bcd
cd d
for some reason it is printing the succeeding characters in the
structure, in unspecified places, arrgh. I get the same problem if I
use the definition:
char a[1];
I can remove the problem if I seperate the variables by some dummy
variable eg:
char a;
int dummy;
char b;
this seems weird to me, any ideas what I'm doing wrong? I'm
using gcc compiler on a SUN SPARC under openwindows and
SUNOS 4.something.
cheers Tom
Tom Charnock
Dept Civil Engineering
Aston University
Birmingham B7 5NJ UK
charnotw@aston.ac.uk
