Hello,
We are having difficulties installing a GTCO L-series digitizer with grass4.1
running solaris 2.3.I would greatly appreciate knowing if anyone has successfully installed a
any digitizer with solaris 2.3. The guidelines do not hold true for installing
Sorry if this is a bit 'me-too-ish' but I would second this request.
Since being upgraded (or should that be downgraded?!) to solaris 2.3
our Calcomp Drawingboard II digitizer refuses to talk to our sun.
Having stuck a terminal between digi' & 'puter v.digit does not seem
to be sending the correct initialisation string from the file in
etc/digitizers as specified in the digicap file.
with solaris as they do fo SUN OS 4.13 and HP. The file structure is quite
different. As many of you know.The cable and dip switches seem to be correct. I suspect it is in setting the
serial port correctly. But the files are quite different and any of the
information in the README files for setting up a digitizer do not apply to
solaris 2.3.If anyone has worked this out we would appreciate learning from your trial ana
errors.Pamela Phillips
Bye, Rob Poole.
