problem w/v.digit on solaris 2.3
In an E-mail message, poolerh wrote:
> Hello,
> We are having difficulties installing a GTCO L-series digitizer with grass4.1
> running solaris 2.3.
> I would greatly appreciate knowing if anyone has successfully installed a
> any digitizer with solaris 2.3. The guidelines do not hold true for installing
Sorry if this is a bit 'me-too-ish' but I would second this request.
Since being upgraded (or should that be downgraded?!) to solaris 2.3
our Calcomp Drawingboard II digitizer refuses to talk to our sun.
Having stuck a terminal between digi' & 'puter v.digit does not seem
to be sending the correct initialisation string from the file in
etc/digitizers as specified in the digicap file.
> with solaris as they do fo SUN OS 4.13 and HP. The file structure is quite
> different. As many of you know.
> The cable and dip switches seem to be correct. I suspect it is in setting the
> serial port correctly. But the files are quite different and any of the
> information in the README files for setting up a digitizer do not apply to
> solaris 2.3.
> If anyone has worked this out we would appreciate learning from your trial ana
> errors.
> Pamela Phillips
Bye, Rob Poole.
You should look at using v.digit2. It solved a similar problem for another
person who couldn't get their Altek digitizer working with v.digit running
under Solaris 2.3. This assumes though, that you have a format file under
$GISBASE/etc/digitizers for you digitizer, and that you use digitcap rather
than digcap (found under $GISBASE/etc).
Paul Loechl p-loechl@cecer.army.mil
USA CERL (217)352-6511x7668
