Problem with installation on SGI's
Check for permissions on all the directories in /u/cipag0/grass/data.
They should be at a minimium r-x for everybody. And spearfish and global
should be rwx for everybody. Also please be more specific when you say
you are "unable to access the databases". What exactly is the problem.
|I am having some probelms installing Grass on SG Personal Iris's running
|Version 3.3.2 of IRIX.
|I am unable to access the databases. I have set up the directories as:
| /u/cipag0/grass
| _______________|_______________
| src bin sgi data src/related etc...
| _______|_______
| spearfish global
| PERMANENT PERMANENT
| _______| _______|
|Is this correct for these setup variables:
|DEFAULT_DATABASE = /u/cipag0/grass/data
|DEFAULT_LOCATION = spearfish
|Thank You
|David Chatterton
|davidc@bruce.cs.monash.edu.au
Michael Shapiro U.S. Army CERL
email: shapiro@zorro.cecer.army.mil Environmental Division
phone: (217) 352-6511 ext 526 P.O. Box 9005
fax: (217) 373-7222 Champaign, Ill. 61826-9005
