Hey everybody!
I've already got another probleme: I can't open any monitors.
I'm working on a PC, not connected to any network and with linux installed
just now to work with GRASS.
Here's the message I get when trying to start the monitors (d.mon):
name description status
x0 X-windows graphics display not running
x1 X-windows graphics display not running
x2 X-windows graphics display not running
x3 X-windows graphics display not running
x4 X-windows graphics display not running
x5 X-windows graphics display not running
x6 X-windows graphics display not running
CELL Create GRASS Raster File not running
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 78 (X_CreateColormap)
Serial number of failed request: 30
Current serial number in output stream: 31
Please start graphics monitor <x0>.
Error - Graphics monitor <x0> not running!
Problem selecting x0. Will try once more
Thanks a lot if you could help
karine
\ Karine ZUERCHER zuercher@sc2a.unige.ch /
/ University of Geneva \
You are using a 24-bit X server with an 8-bit GRASS Monitor.
Try using the XDRIVER24 program instead. If you change etc/monitorcap,
things will work.
Good luck.
Angus Carr.
On Thu, 25 Jun 1998, Karine ZUERCHER wrote:
Hey everybody!
karine
This message generally occurs when you use XDRIVER with a X-windows
server in true color (16 or 24 bits)... You have two choices :
- use a 256 color X-windows server (and have a bigger
logical screen size...
- use XDRIVER24 instead of XDRIVER (better solution, works
with all X11 color models
BTW, another question : why still distribute XDRIVER ? Looking at
sources, XDRIVER24 is just an enhancement of XDRIVER, and may be
considered as the current version... another thing to clean...
Michel Wurtz ENGEES - Laboratoire Territoires & Environnement
1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
Tel: +33 03.88.25.34.62 Fax: +33 03.88.37.04.97
Hey everybody!
karine
Perhaps your problems comes from the configuration of your monitor (Pc´s
monitor). GRASS works with 8 bits colormap, and if you have a monitor
with an higher resolution (16 bits, or 24 bits), GRASS can't open his
display monitor. Try to configurate your monitor resolution with
Xconfigurator in Linux. Choose an 8 bits resolution, so open startx and
try to open one GRASS monitor display.
Try it and tell me if it works.
Alexandre Rodier
INUAMA
Universidad de Murcia
Campus de Espinardo
30100 - MURCIA -
- SPAIN -
