probleme opening monitors
x5 X-windows graphics display not running
x6 X-windows graphics display not running
CELL Create GRASS Raster File not running
X Error of failed request: BadMatch (invalid parameter attributes)
  Major opcode of failed request: 78 (X_CreateColormap)
  Serial number of failed request: 30
  Current serial number in output stream: 31
you can use GRASS with 8bit as well as 24bit. You just have
to set the link in grass42/driver to the proper driver.
The message "X_CreateColormap" indicates that the link is
currently set to the wrong GRASS-Xdriver.
Available are the following Xdriver:
ls -la /grass42/driver/
   drwxrwxrwx 2 neteler user 512 Jun 25 17:15 .
   drwxr-xr-x 13 neteler user 512 Jun 25 17:15 ..
   -rwxrwxr-x 1 neteler user 96364 Jun 25 17:15 CELL
   lrwxrwxrwx 1 root other 9 Jun 15 15:21 XDRIVER -> XDRIVER_8
   -rwxr-xr-x 1 neteler user 41880 Apr 2 10:59 XDRIVER_24
   -rwxr-xr-x 1 neteler user 41660 Apr 2 10:59 XDRIVER_8
The link MUST certainly fit to the configuration of XSERVER of
your Linux/SUN/HP, whatever you use. Getting this error message,
you either change the color depth of your X11-XSERVER or the link
onto the GRASS driver.
Hope this helps
    Markus Neteler
Geographisches Institut | Institute of Geography
   Physische Geographie Physical Geography
& Landschaftsoekologie & Landscape Ecology
Universitaet Hannover University of Hannover, Germany
                     neteler@geog.uni-hannover.de
             http://www.geog.uni-hannover.de/users/neteler/
