David,
I don't think there was any attempt to update the xgrass code
for the floating point version. The Categories structure was
changed for this version so any code that accessed the
structure directly will be in trouble - there should be a way
to use the programmer's interface routines to replace the
offending code - but there will probably be other instances
where xgrass accessed structures (such as Colors) directly, so
you would have to do the same for such cases.
- Bill
I've hit a snag with the DEC Alpha port of GRASS.
The problem seems to be in the file src/include/gis.h extracted from the
fp_main.tar.Z archive in the Floating_pt update: this omits the structure
Cat_list within the definition of structure Categories (at about line 51).
The compilation of src/xgrass/display/crtecolor.c then fails because
it attempts to refer to elements of the (now omitted) nested structure.Is there a way round this? What is the recommended order of unpacking the
standard sources and any updates?
