Dear Sirs
I work on unix Convex Computer with o.s. 9.1 with graphic interface
DECSTATION 5000 RISC.
Last spring I took from public domain address grass4.0 software to
install it for the first time on my Convex.
I haven't found any problems with setup or compilation program, but
now I am not able to setup properly my graphic station.
After GISGEN generation I have done these operations :
- run gmake4.0 into directory grass4.0/src/display/devices/XDRIVER
- edit file grass4.0/etc/monitorcap and setup only the configuration
of x0 terminal (uncommenting only the interesting lines but
unchanging the text)
Now when I use d.mon program is possible to see my configuration
station (option 3) in the list, but the program fail when i try
to use option 1 answering :
" Error Graph_Set : can't open " .
Note that this kind of error appear when I didn't forced any external
graphic display; otherwise if I set my display (setenv DISPLAY
mystation:0.0) grass4.0 answer :
XIO : fatal IO error 11 (resuorces temporarily unavailable)
on X server "(null)" after 0 request (0 know processed) with 0
eventes remaining .
There is a person so kind to tell me how to solve this problem ?
Lately I have seen on public address a new compress file named XGRASS,
this file is big (40Mb) for my stressed disks, so do you think that
this could be a useful way to resolve my problem or there is a
simple metod to bypass my configuration problem ?
Sincerely Regards
Bruno Minoja
address :
Bruno Minoja
Cilea
Via R. Sanzio 4
Segrate Milano (Italia)
minoja@icil64.cilea.it (131.175.1.5)
