Problems to install GRASS in Sun Solaris 2.5.1
Hi, I am a new comer of GRASS and get some trouble how to install
GRASS4.1 (Update 5) in Sun Ultra Sparc running Solaris 2.5.1.
(1) When I compile it using the Sun CC, I get the following error message:
       ld: fatal: symbol `Def_term' is multiply defined:
        (file /usr/ucblib/libcurses.a(curses.o) and file
        /usr/ccs/lib/libtermlib.a(setupterm.o));
(2) Using Gnu gcc, I can install it sucessfully. But when I run:
  d.mon start=x4, I get a graphic window and error message:
  GRASS 4.1 > d.mon start=x4
  Graphics driver [x4] started
  Please start graphics monitor <x4>.
  Error - Graphics monitor <x4> not running!
  Problem selecting x4. Will try once more
Can anyone help me out?
Thanks very much
Peizhong Wu
Atmospheric, Oceanic and Space Science Department
University of Michigan
Remove /usr/ucblib from your LD_LIBRARY_PATH environmental variable.
Everything should be fine then.
Check that the $GISBASE/locks and any subdirectories under it are
read/writeable by everyone. Good luck!
  -Malcolm
Thanks very much
Peizhong Wu
