problems to open graphics device
I got an error message when I tried to open GRASS monitor from a remote PC. The error
message is:
X Error of failed request: BadMatch (invalid parameter attributes)
    Major opcode of failed request: 78 (X_CreateColormap)
    Serial number of failed request: 227
    Current serial number in output stream: 228
Error - Can't set up pipe to graphics device.
Problem selecting x1. Will try once more.
By the way, it doesn't have that problem when I run GRASS from the SUN console. I
think I set the "xhost" correctly in my PC and I have no problem to
link to open windows/graphics from other software remotely.
I am a new user in using GRASS. Thank you much for your help.
S.X. Wu
Free web-based email, Forever, From anywhere!
http://www.mailexcite.com
The standard GRASS xdriver only works on 8-bit graphic displays. Check
your PC display to be sure that it is set to 256 colors. If you wish to
be able to display on a PC running more than 256 colors, you'll need to
get the contributed "24XDRIVER" code off of GRASS ftp site. This will
provide you with a GRASS 8-bit display window that will work on 24-bit
desktops. Good luck,
Malcolm D. Williamson - GIS Specialist E-mail: malcolm@cast.uark.edu
Center for Advanced Spatial Technologies Phone: (501) 575-6159
Ozark Rm. 12 Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701 Web: http://www.cast.uark.edu
On Tue, 10 Mar 1998, sx Wu wrote:
message is:
S.X. Wu
My x-server for Windows runs the standard 8-bit monitor on my (24-bit)
graphics screen. This might be an easier solution than compiling the
XDRIVER24 code, as you won't need to change GRASS at all, just your PC.
The one I use is 'Micro X-Win32' for Win95/NT (around $200 from Starnet:
sales@starnet.com). You simply tell the server to do 'Pseudocolor
support in 24-bit mode' and it fools the grass 8-bit monitors into
thinking they are working on a pseudocolor display. You can get a demo
of this which runs for 2 hours at a time, to test this out. Other
x-servers (e.g. StarNet's Win3.1 version, or Vista eXceed, or the one
packaged with NT server) might do this as well now for all I know.
Just a thought.
David Wheatley
Department of Archaeology
University of Southampton
to be able to display on a PC running more than 256 colors, you'll
need to get the contributed "24XDRIVER" code off of GRASS ftp site.
This will provide you with a GRASS 8-bit display window that will work
on 24-bit desktops. Good luck,
> Hi,
> remote PC. The error message is:
> SUN console. I think I set the "xhost" correctly in my PC and I have
> no problem to link to open windows/graphics from other software
> remotely.
