Well, I think this is the problem. You only have one PsuedoColor
visual and it isn't large enough. 16 colors isn't enough to run GRASS.
|>| We're trying to run GRASS on a PC running DESQview.
|>|The problems experienced with old xdriver:
|>| 1. Vector maps (even color) can be displayed without any problem.
|>|But
|>| 2. When we try to display a raster map, it gives a bunch of error
|>|messages like,
|>| X Error (major opcode 72 -- XPutImage). and the monitor dies!!
|>|Problems with new XDRIVER:(for GRASS running on a PC through DESQview)
|>| 1. When we start the monitor (d.mon start) it self it says
|>| "Color: Can't set color 0"
|>| 2. When we try to display a color vector map it doesn't use the
|>|assigned color (infact no color can be displayed at all)
|>| 3. When we try to display a raster map the monitor dies saying
|>| "Segmentation fault"
|>|Laxmi P. Musunur (LP)
|>If you have the command xdpyinfo, run that and send the output from this
|>command to the list. The GRASS XDRIVER assumes that the Default Visual
|>is PsuedoColor, and I would like to see if that is true for you server.
|>xdpyinfo is a command I use to dump a lot of info about the X Server
|>and among this is info about all visuals you serve supports.
| Here is the xdpyinfo for my X server: thankyou .. Laxmi P. Musunur (LP)
| xdpyinfo for DESQview/X PC
|name of display: 131.204.43.37:0.0
|version number: 11.0
|vendor string: DESQview/X (R), by Quarterdeck Office Systems
|vendor release number: 100
|maximum request size: 4096 longwords (16384 bytes)
|motion buffer size: 0
|bitmap unit, bit order, padding: 8, MSBFirst, 32
|image byte order: MSBFirst
|number of supported pixmap formats: 2
| depth 1, bits_per_pixel 1, scanline_pad 32
| depth 4, bits_per_pixel 4, scanline_pad 32
|keycode range: minimum 8, maximum 124
|number of extensions: 2
| SHAPE
| Quarterdeck Extensions
|default screen number: 0
|number of screens: 1
|screen #0:
| dimensions: 800x600 pixels (240x180 millimeters)
| resolution: 85x85 dots per inch
| depths (2): 1, 4
| root window id: 0x80067
| depth of root window: 4 planes
| number of colormaps: minimum 1, maximum 1
| default colormap: 0x80065
| default number of colormap cells: 16
| preallocated pixels: black 0, white 15
| options: backing-store YES, save-unders NO
| current input event mask: 0x70003c
| ButtonPressMask ButtonReleaseMask EnterWindowMask
| LeaveWindowMask SubstructureRedirectMask FocusChangeMask
| PropertyChangeMask
| number of visuals: 1
| default visual id: 0x80064
| visual:
| visual id: 0x80064
| class: PseudoColor
| depth: 4 planes
| size of colormap: 16 entries
| red, green, blue masks: 0x0, 0x0, 0x0
| significant bits in color specification: 6 bits
Michael Shapiro U.S. Army CERL
email: shapiro@zorro.cecer.army.mil Environmental Division
phone: (217) 373-7277 P.O. Box 9005
fax: (217) 373-7222 Champaign, Ill. 61826-9005
