I'm having problems with g.help. When the command is given the menu appears
however it does not respond to the RETURN key and the only way to select only
some of the topics is to scroll down and force the asterix to move. When
g.help is left (with SPACE), the grass shell no longer works - it only responds
to CTRL-C keystrokes as if the stdin buffer was being directed elsewhere.
I am also having problems with the Iris window monitor. Should this window
automatically update when the window is moved/resized or does this have to
be done manually?
This system has been installed upon SG Personal Iris's running 3.3.2 of Irix.
Thank You
David Chatterton
davidc@bruce.cs.monash.edu.au
