Dear users:
I Installed GRASS 4.2.1 from binaries and I worked with it without
problems
I also have installed postgres database and it runs properly
Now I've compiled it from the sources in order to add new modules,
specially those that link GRASS with postgres database. It works fine,
but the *.pg modules seem not work.
g.select.pg seems to work properly, but when I try to use other modules
I get error messages like:
ERROR: attribute '_pg' not found with g.table.pg
ERROR: attribute 'table_name' not found
ERROR: parser: parse error at or near "{" with g.stats.pg
The database I used is correct, I have worked with it in postgres, other
hand the error messages seem to be due to a bad query construction.
Finally, I work with Linux 2.0 and a PENTIUM-166
Has somebody any idea that could help me?
Thanks in advance
Francisco Alonso
Area de Geografía Física
Universidad de Murcia
Campus de La Merced
E-30001 Murcia SPAIN
Tel: (968) 364357
